how much boost is safe for stock b17?
Its not about the boost level...its about how much power it can handle. Most B series engines are safe into the 330-350whp range...some people have pushed them further, but beyond the mid 300s, you're rolling the dice.
we make ~500 all the time on stock bseries they are reliable and last 20k+ miles its just all about a healthy motor and a good tune
the b17 is no weaker so you will be fine
well i was starting to think you guys were talkin about the blocks themselves ******* ie stock block and sleeves with forged internals. i havent heard of anyone making numbers like that with stock internals.
https://honda-tech.com/forums/showth...ht=stock+block
There is no number. And I dont believe its a crapshoot. If the motor is healthy, and tuned safley, you can pump as much power as you want through it. The margin of saftey as far as things breaking decreases with more power because the heat is much greater and the slightest detonation increases cylinder pressures tenfold and that is what breaks ****. All your doing when putting forged internals in is increasing that margin. A bad tune or detonation is still gonna kill things then to.
KidFrost
14
Sep 19, 2010 02:37 PM
