Turbo Install almost complete. Just need last minute help please!
Old Apr 5, 2011 | 11:22 AM
bmbarnum's Avatar
Default Turbo Install almost complete. Just need last minute help please!
Crappy cell phone picture
So, I just need help running my vacuum lines. I will be running the BOV line directly to a vacuum port on my golden eagle vacuum box. Next, I will have the source of the vacuum box tee'd off from the Brake Booster line. Behind my intake manifold is an open port, I will be using that port to have my wastegate line run directly to it since the wastegate should ONLY see pressure not vacuum, correct? Lastly, I will have my boost gauge, which will be in the cabin, line connected to another Vacuum Port on my Golden Eagle box.
I was wondering if this is correct. I am not too sure about my boost gauge line and my wastegate line.
Thanks! Want to get this install complete already
Old Apr 5, 2011 | 11:52 AM
kyden's Avatar
Default Re: Turbo Install almost complete. Just need last minute help please!
that line your wastegate is going to is the same as a line from the vacuum box. do you have a fitting on the compressor housing to use instead? a non-vacuum source would be pre-throttle body.
Old Apr 5, 2011 | 12:00 PM
TURKISHFORCE's Avatar
hi Selam
in my setup is the Brake Booster line the same Connection? no need install on the vacum box??
the wastgate pipe must install before the throttle body. my is on the plase like yellow BOV written is ..
you can use all vacum on the box (bov/gauge/)
Old Apr 5, 2011 | 12:01 PM
bmbarnum's Avatar
I don't have a fitting on my housing. I'm running the GT28rs. Maybe I can just get one of those couplers that have a fitting on it?
Old Apr 5, 2011 | 01:48 PM
Turbo-LS's Avatar
Be careful running the BOV off a shared vacuum source, some bov's like to have their own source. Just an FYI if the bov doesnt sound like its working then get it to an independent source
Old Apr 6, 2011 | 04:46 AM
BigMike0147's Avatar
I'm wondering the same thing. If your turbo isn't tapped for this, what do you do then??
Old Apr 6, 2011 | 07:54 AM
Turbo-LS's Avatar
you can drill and tap the compressor housing your self, its not hard but do it with the turbo off the car and compressor housing removed and be sure to clean it really well afterwards
crex23
Mar 16, 2014 02:37 AM
Muckman
Apr 18, 2006 03:42 PM
PhantomX
Apr 18, 2006 02:35 PM
egvtec
Jan 9, 2005 09:25 AM
wickedxboi
Feb 28, 2003 09:07 AM
