b16a obd0 ef help!!!
Old Apr 3, 2011 | 01:07 PM
sinaloa_ef's Avatar
Post b16a obd0 ef help!!!
ok well i just swapped my 89 civic si with a b16a 0bd itr manifold ctr pistons and it starts but wont stay on unless i add gas. just changed the map sensor and checked the timing and its all good. please help.
Old Apr 3, 2011 | 03:02 PM
Projekt_Ef9's Avatar
Default Re: b16a obd0 ef help!!!
Is it giving any codes or a check engine light. Have you checked the TPS, FITV, and IACV?
Old Apr 3, 2011 | 03:14 PM
gringo7718's Avatar
B16 with ITR pistons is going to need a Chipped ECU to run custom fuel/ignition maps. I would assume that the stock ECU would run so lean it could cause detonation or ka-Blam.
You say the engine timing is correct (timing belt).
Did you use a timing light to properly set the ignition timing? http://www.c-speedracing.com/howto/timing/timing.php
1. Properly adjust Idle Speed - http://webpages.charter.net/mrfatbooty/pics/idle_1.jpg
2. Check and adjust TPS. - https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
3. Check/Clean the IACV - Carb Cleaner FTW
4. Reset ECU - Remove 10amp fuse in engine bay fuse box for 20 sec.
Old Apr 3, 2011 | 05:05 PM
sinaloa_ef's Avatar
i am running a zdyne obd0 ecu for a b16a not sure if thats good for the ctr pistons and
put a new tps also
Old Apr 3, 2011 | 05:31 PM
gringo7718's Avatar
That setup will most probably require more fuel than the stock B16 map is designed for so don't push it until it gets tuned. If it were me, that would be sooner than later.
As far as tuning goes, I dont know that much but the general agreement is that you will get the best results with obd I. You may be able to re-tune the Zdyne but obd-I has superior ignition timing abilities to obd-0 which will be important to provide the most power and best protection for your motor. Obd-I seems to have the best support and programs and you can actually buy headers etc. etc.
Find a good tuner and talk to them. Dont be surprised if they ask you to upgrade programming/fuel system. If they use and like a specific program (Hondata Zdyne) because they know how to manipulate it well, it may be worth it to upgrade rather than forcing them to work on programming they don't like
Old Apr 3, 2011 | 05:38 PM
sinaloa_ef's Avatar
would u think the obd0 zdyne do the job i was running the pr3 at first i would have to keep my foot on the gas for it to stay on and it i would rev it no power at all but with the zdyne it revs up but still turns off with out my foot on the gas.
Old Apr 4, 2011 | 12:08 AM
hatchet_honda's Avatar
integra mani on a b16 head? thought they had diff bolt patterns
Old Apr 4, 2011 | 05:11 AM
gringo7718's Avatar
ITR / CTR / B16 have same bolt pattern on IM. I have heard that on a B16, the best manifold is P30 (obd-1 b16 manifold) but I have no data to back this claim up.
Old Apr 4, 2011 | 06:22 AM
so then its just the gsr intake that fits diff?
Old Apr 4, 2011 | 07:33 AM
SIef9's Avatar
there is a screw on the throttle... i unscrewed as if i was taking it out and it stop doing that i had the same problem with my b16 when i put it on n a buddy of mine told me to do that and my car is legit no problems
by the way i have a obd0 pw0 tuned eriks racing for a b20 vtec idk if that would help you ill llet it go for cheap let me kno
Old Apr 4, 2011 | 07:54 AM
Afshin9393's Avatar
i was using this set-up before (pr3 b16a with p30 IM). had good improvement in performance. none of the pr3 b16a i know of is using a CTR IM. i know that those with p30 b16a usually will swap the IM with an CTR's.
Old Apr 4, 2011 | 07:56 AM
Afshin9393's Avatar
from what i know, all b-series except for the b18c gsr has different bolt pattern. when buying aftermarket IM the seller would ask if the engine is a b18c gsr or otherwise.
b16DooD
Jul 14, 2011 07:47 AM
riddlinkid1986
Aug 14, 2007 08:13 PM
civicex_88005
16
Jul 8, 2005 06:02 PM
hatchinprogress
Jan 7, 2005 10:06 AM
out2wincrx
Jan 15, 2002 07:22 PM
