LOW idle after cleaning IACV???
Old Apr 2, 2011 | 04:42 PM
hannslebo's Avatar
Default LOW idle after cleaning IACV???
Well I finally got a chance to do some things things to my civic today.
1994 honda civic (d16z6)
I decided to clean the IACV along with plugs, thermostat, VC gasket and tube seals.
I got done put it all back together and it seems to idle around 450-500ish rpms. It doesent shut off on me or anything.
It runs alot better when im driving...and it seems to idle smoother, but it just idles a bit lower than before. Before it idled at about 650ish?????????????
Think i need to clean the FITV and adjust?
Old Apr 2, 2011 | 04:43 PM
Project H's Avatar
Default Re: LOW idle after cleaning IACV???
did you adjust your idle speed?
Old Apr 2, 2011 | 05:30 PM
hannslebo's Avatar
No. I just cleaned the IACV, installed new plugs, thermostat, VC gasket and spark plug seals.
I did not mess with the FITV or the idle screw.
Old Apr 2, 2011 | 05:36 PM
Project H's Avatar
did yo mess with the cable any?
Old Apr 2, 2011 | 05:44 PM
hannslebo's Avatar
Nope. Not at all.
Old Apr 2, 2011 | 07:04 PM
hannslebo's Avatar
Or does it just need to adjust to the fresh iacv?
Old Apr 2, 2011 | 07:11 PM
civicsmoke's Avatar
could it be when you were putting the iacv back together you screwed the plastic peice that holds down the metal bullet looking thing to far? I've heard that can be a cause to low idle after cleaning. I dont think your supposed to screw it in all the way, atleast i didnt and mine idles perfect.
Old Apr 2, 2011 | 07:28 PM
hannslebo's Avatar
U talking about the round black plastic piece that comes off the sside?
Old Apr 2, 2011 | 07:37 PM
Katastrophic's Avatar
my lx did a similar thing last week after i got it smogged and cleaned. It would hover around 5-600 for 2 days but after a few days of driving around it returned to 1000ish
how long has it been doing this, if not long give it a few days if you see no change then you may have a bigger issue.
Old Apr 3, 2011 | 06:16 AM
Red_Army's Avatar
its supposed to be at 650 +/- 50.
so your alright. being at 1000 is way high.
Old Apr 3, 2011 | 06:41 AM
HondaPartsHero's Avatar
Technical Hero
I think you're talking about the FITV not the IACV. Here's the idle relearn procedure:
Old Apr 3, 2011 | 07:20 AM
civicsmoke's Avatar
^ ya i was just coming back in here to correct that, my bad.
Old Apr 3, 2011 | 07:33 AM
that_boy_sammy's Avatar
Yeah dude just loosen the idle screw(lefty loosey righty tighty) so a little bit more gas can flow through because it had different readings with your dirty iacv.
Old Apr 3, 2011 | 09:46 AM
hannslebo's Avatar
Thanks for all the help fellas...the car is now running smooth...I drove it about 30 miles since ive cleaned it...and now it is hanging around 700! Guess it just needed a lil time to adjust??? Anyways, all is good!
THANKS!
mhernandez
14
Dec 31, 2012 04:20 PM
jEE
10
Mar 3, 2011 01:02 PM
blackeg
Sep 17, 2008 06:01 PM
4ghatch
Sep 28, 2005 02:59 AM
DC2*Integra
Sep 20, 2005 12:51 PM
