Rsx 02 starting problem!!!! Please help :-(
Old Apr 1, 2011 | 12:41 AM
crxb16a90's Avatar
Default Rsx 02 starting problem!!!! Please help :-(
Helping my friend rsx, he bought it
From. Someone that it wasn't running, here's the problem, motor is fine, but no crank(starter dont turn) no Cel or light won't come one at all, no fuel prime, fuel pump dont come on at all, but everything's else come on, even maintenance light come on,
Replace ecu, charged the steering column with a matching key, still the same, battery full charged, check all fuse, replace with known good
Relay, still nothing, if u click it just right on starting, it will make a buzzy noise on the red relay, and check engine and anti theft wil flicker. But no starter or fuel prime. I m running out of idea plus I m new to k series, any idea, nay be something happen before? Any info will help,
The person we got it from said car drive fine and park for the night and come out in morning, and it went dead, replaced starter and nothing, they said they checked starter was getting 5v, I don't know what the anti theft actually do, cut starter too???? Anyway thanks
Old Apr 1, 2011 | 06:52 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Rsx 02 starting problem!!!! Please help :-(
sounds like it's out of your hands. You probably want to tow it to a shop at this point and bite the bullet.
Do you have a power tester? I would check all of the circuits for good power and bad grounds.
Also, check your grammar lol makes it hard to read.
Old Apr 1, 2011 | 07:37 AM
crxb16a90's Avatar
Sorry bro, I was in a hurry.
We thought about that, but I been working on Honda for 14 Yrs, and tuning over 3 Yrs, I don't want to give up yet, lol.
I just all the fuses, point to point they are all good,
I think relay, something is keeping the ecu from thinking, either no signal being send to ecu to tell it come on or something
Old Aug 8, 2011 | 06:03 PM
DreamRSX's Avatar
Hey crxb, I'm having the same problem...Did you ever find out the problem>?
Old Sep 7, 2011 | 08:42 AM
whitehf's Avatar
im having the same problem...but when i open up my gas cap to release the pressure it turns on...i noticed when it doesnt turn over, the cel doesnt come on..
Old Sep 12, 2011 | 09:53 AM
DreamRSX's Avatar
Hey CRX! I found out my problem towards my Acura RSX not starting up! WHITEHF, this might help you out! I have a Manuel tranny, so what I did was I pumped the clutch pedal while turning the key and it worked. Yup, as simple as that. I guess something was wrong with the clutch safety switch. So I decided to run a wire from the starter direct to a push start switch I have inside the car. Now I have to make sure before I start the car that it's in neutral. LoL... But it's up and running everytime! Nice... Hope this helps you..
Old Sep 12, 2011 | 11:29 AM
whitehf's Avatar
my rsx is an auto and its still not starting up..im thinking about changing out my fuel pump relay..
Old Sep 27, 2011 | 11:30 PM
crxb16a90's Avatar
Actually I did, they did a battery relcoTed, I checked start didn't get a ground, which starter ground off the motor, so I put it back to stock and using stock ground wire and it start right up
Old Oct 3, 2011 | 12:42 PM
whitehf's Avatar
So i replaced my fuel pump relay and fuel pump and car is still not starting...my car wasnt starting be cause i had a loose ecu connector. when i turned it to the on position and pushed the connector in, i heard the click from the fuel pump relay and my CEL came on. ALL THAT FOR A LOOSE CONNECTOR.
I also failed smog about 2 weeks ago because of the bad ecu. The smog tech said everything passed but the ecu keeps deleting everything. But after i secured the connector and drove it 50miles non stop, the car passes smog with flying colors.
YungCee
Sep 23, 2016 10:28 AM
Acuranoob
Nov 30, 2014 07:34 PM
whitehf
Dec 5, 2011 06:14 PM
thenumber24
Dec 3, 2011 02:15 AM
raymas8
10
Jul 29, 2005 04:50 PM
