Type-'S'paz Official DIY thread!
I figured Spaz since you do a ton of them might as well put them all the links here!!!
Thanks for the good work and keep it up... it's great having a guy like you helping the community
Replacing/Pressing Motor Mount Bushings or any bushing really
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/diy-replacing-pressing-motor-mount-bushings-2916830/
Installing Fuel Pump
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/fuel-pump-instal-diy-2756195/
Adding a Fuel Return System
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/fuel-return-diy-2905850/
Fuel Line replacement with aftermarket rail
https://honda-tech.com/forums/showthread.php...1#post44974531
Helpful Engine Swap Videos
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/helpful-video-2853944/
Bleeding Clutch/Brakes yourself
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-easy-way-bleed-clutch-brakes-yourself-2914020/
Making your own intake Mixture of SRI/CAI
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/intake-i-made-my-swap-gonna-try-out-2912061/
Modifying Beaks Bar to fit Progress Bar
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/diy-modifying-beaks-bar-progress-brace-2869941/
Changing Radiator Hoses
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/hybrid-racing-silicone-hose-install-review-2889506/
Shaving your Throttle Body
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/my-crazy-throttle-body-shave-d-i-y-2869123/
Honda Key Conversion
https://honda-tech.com/forums/showthread.php...8#post44974448
Boring throttle Spacer or Manifold
https://honda-tech.com/forums/showthread.php...9#post44974459
Making your own clutch line
https://honda-tech.com/forums/showthread.php...6#post44974476
Replacing Clutch Master Cylinder
https://honda-tech.com/forums/showthread.php...0#post44974490
Making your own gaskets
https://honda-tech.com/forums/showthread.php...5#post44974505
Cleaning Up tucking Throttle Cables
https://honda-tech.com/forums/showthread.php...0#post44974510
Compression Testing your engine
https://honda-tech.com/forums/showthread.php...4#post44974514
Cleaning and Painting your inner rims
https://honda-tech.com/forums/showthread.php...8#post44974538
Installing Cusco B-pillar bars and Harness Bar
https://honda-tech.com/forums/showthread.php...0#post44974550
Touching Up bay paint
https://honda-tech.com/forums/showthread.php...7#post44974557
Fender Rolling
https://honda-tech.com/forums/showthread.php...8#post44974568
Electronic Power Steering into DC5
https://honda-tech.com/forums/showthread.php...7#post44974577
Fuel Return DIY
https://honda-tech.com/forums/showthread.php?t=2905850
D.I.Y Valve Adjustments
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-valve-adjustments-2917144/
D.I.Y Red Door Inserts / Removing door panels
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-red-door-inserts-removing-door-panels-2917148/
Installing Hood Dampeners
https://honda-tech.com/forums/showthread.php...1#post44974811
Painting A-Pillars Black
https://honda-tech.com/forums/showthread.php...7#post44974897
Battery in the Hatch
https://honda-tech.com/forums/showthread.php...2#post44974932
Removing Air Pocket in Coolant system
https://honda-tech.com/forums/showthread.php...1#post44974951
D.I.Y ITR Pedals Install
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-itr-pedals-instal-2917152/
EP3 Steering Wheel Swap
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-ep3-steering-wheel-swap-2917235/
Redline Shift boot and stock collar
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-redline-shift-boot-stock-collar-2917239/
Rear Wiper Delete Plug Instal
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-rear-wiper-delete-plug-2917241/
D.I.Y Swapping Tails or Replacing Gaskets (05/06 rsx)
https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/d-i-y-swapping-tails-replacing-gaskets-05-06-rsx-2925797/
Fender Rolling
Fuel Return DIY
dalilenginedatcud
Apr 27, 2007 06:15 PM
