turbo specs?
Old Sep 27, 2002 | 01:11 PM
austrian type-R's Avatar
Default turbo specs?
I have the Turbo which comes in the DRAG III kit, Turbonetics T3/T04e
I wonder which A/R and trims this turbo has......and what to modify when I want a bit more top end.
Old Sep 27, 2002 | 01:13 PM
b18bturbo's Avatar
Default Re: turbo specs? (austrian type-R)
.63 ar exhaust with .54 trim compressor. or it could be something slightly different but thats what most of them are.
Old Sep 27, 2002 | 03:08 PM
Default Re: turbo specs? (b18bturbo)
exhaust trim is okay IMO, but compressor a/r is a bit too small, right?
What means 54 trim or 60 trim?
Old Sep 27, 2002 | 03:23 PM
b18bturbo's Avatar
what i would do is t3 60-1 or something in that neigboorhood i know louis is doing a gb on them right now. with .82 housing that should spool slower but more top end.
Old Sep 27, 2002 | 04:20 PM
Sonny's Avatar
The trim is reference to the compressor wheel's size and ability to flow air. The 60 trim wheel will flow more than a 54 trim wheel. The 60-1 compressor that Viren mentioned will make awesome power, but it requires a new wheel, new compressor housing, and new backplate.
Sonny
Old Sep 28, 2002 | 10:13 AM
Default Re: turbo specs? (Sonny)
I do lots of autoX and I am happy with my relatively wuick spool, I don't wont to miss it. I get a new turbo manifold which is supposed to give a quicker spool (tubular mani). Therefore I thought about to modify the turbo slightly, I only want a bit more top and and no big lag.
Old Sep 28, 2002 | 10:24 AM
b18bturbo's Avatar
if you do it slightly take it up to larger compressor side trim.
Old Sep 28, 2002 | 10:38 AM
yeah, that it was I thought, but what a7r would be a wise choice
Monkey Z.
Nov 6, 2005 02:34 PM
Dee
Feb 28, 2005 05:53 AM
ludelvr
Jul 30, 2003 09:08 AM
4U2NV
Dec 29, 2002 11:06 AM
B20bTurbo
May 8, 2002 10:11 PM
