Just got turbo and need some advice...
Old 12-27-2002, 08:15 AM
4U2NV's Avatar
Default Just got turbo and need some advice...
Is there ne way to tell from the outside if a turbo is a t3/t04b or e...? On the compressor side it says A/R .60 and the exhuast housing says A/R.48... Will this turbo work well on an LS Teg... How quickly do you think it'll spool and will this turbo work well with low boost...? Ne help is appreciated...
Old 12-27-2002, 08:20 AM
ArizonaTurbo's Avatar
Default Re: Just got turbo and need some advice... (99 B18B)
A T04E compressor wheel will have 6 double blades and the T04B compressor wheel will have 7 double blades.
Old 12-27-2002, 08:24 AM
4U2NV's Avatar
Default Re: Just got turbo and need some advice... (TurbochargedSER)
Aight I checked and it has six double blades, and t3/t04e is better than the b, correct...? Can neone help with the other questions...? Thanx in advance...
Old 12-27-2002, 08:32 AM
It sounds like you have a .60 A/R compressor housing. It can have a couple of different compressor wheels in that housing, unless it is a newer Garrett Ballistic Concepts T3/T04E. If it is a Garrett T3/T04E, then it can either have a 57 or 60 trim compressor wheel. If it is a Turbonetics T3/T04E, then it can have a 50, 54, 57 or 60 trim compressor wheel. The .60 A/R compressor housing is the largest housing in the T04E family. It can flow up to 53 lb/min if you have a 60 trim compressor wheel. Since it has a .48 A/R Turbine housing, it will spool quick and make pretty good low/mid power. I am guessing that it will have a smaller compressor wheel since it is a .48 A/R turbine housing. If it is a Garrett, then it has a 57 trim compressor wheel for sure. It wil work fine on the B18A/B. Is this a stock motor?
Old 12-27-2002, 08:41 AM
4U2NV's Avatar
Yes it is a stock motor... Don't have the money for a build up yet but wanna have the fun of boost so I'm trying to run a safe psi... Also yes it is a Garret... I was planning on running 6-8psi with an inline fuel pump and 12:1 fmu... Thanx again...
Old 12-28-2002, 02:39 PM
Smarter than you
DIRep972's Avatar
bring it by the house and we will measure the wheel to find the turbo trim.
Old 12-29-2002, 08:10 AM
4U2NV's Avatar
Default Re: Just got turbo and need some advice... (DIRep972)
Aight, gimme a call when you're there and I'll bring it bye...
Old 12-29-2002, 11:06 AM
Type Wah's Avatar
I'm doing the same thing dawg, except with a T3 Turbo.. just wanna be a lil quicker on the streets..
doc
11-08-2005 07:26 AM
89dxhunchback
08-08-2005 07:08 AM
HYBRID_H@TCH
08-26-2003 12:30 AM
ls-t del sol
02-22-2003 01:36 PM
B00STeD
08-21-2002 03:59 PM
Quick Reply: Just got turbo and need some advice...
