93 CX B15 Swap
Old Mar 27, 2011 | 12:59 PM
chevmaro's Avatar
Default 93 CX B15 Swap
Hi guys. I just bought a 93 CX hatchback. Really liking the car but it has the turd d15b8. I have decided to swap a jdm d15b vtec. Mostly because of cost and it sounds like an easy swap. I cant have too much down time on the car because i drive it every day so I need to research what I need before hand.
Engine
P28 ECU
Vtec Solenoid
Vtec Rywire Harness
Is that it? Does the Solenoid usually come with drop out engines? If I run the stock ecu temporarily will it be ok? I have $800 right now I can use to get the engine in and can add the vtec and new ecu in a couple weeks when i get more money. I figure I should be able to get the engine shipped for about that.
Miss typed the title haha sorry.
Old Mar 27, 2011 | 01:11 PM
CEPerformance's Avatar
Default Re: 93 CX B15 Swap
Yes running the stock ecu will be fine.
and yes, the solenoid comes with the swap usually.
and no, you don't need a rywire harness.
VTEC is 3 wires it would take a monkey 45 minutes to wire your vtec...
you should be able to do it in 30
Old Mar 27, 2011 | 01:31 PM
chevmaro's Avatar
what about using the d15b8 distributor is that ok?
Straits514
Apr 19, 2006 12:29 PM
Naoh_97
10
Feb 14, 2005 10:40 AM
EK FLY
Sep 12, 2004 05:04 AM
roydogg
Aug 4, 2003 10:15 AM
