good compression ratio
I plan on building a poor man type-r engine soon. I've been messing with the compression calculator and I am looking at around 11 for the CR.
What's a good CR for street use? passing smog? pump gas?
any info is great from the Honda Gods ..... none of that BS talk
thanks again guys
thanks again guys
what block and head are you using? a simple way to good poor man type r is a gsr block and a b16 head, you still be around 10 CR, which could pass smog.
11 CR you get when using pr3 piston on a ls block or civic type r piston (12 CR)
