D16Y8 code 70
Anyone out there know to fix this darn issue.....Im currently working on a 97 civic ex automatic.....have transmission issue, everytime the transmission warms up the check engine light comes on. I went ahead and replace the tranny with a new/used and still the same issue....I shorted all the solenoids, changed it all out and same code comes on....please advise folks....
Code 70 tells you there is an automatic transmission trouble code. Pull the specific code with a code reader, or jump the service connector and read the code that blinks from the cluster D4 light.
Hey, glad I could help. DTC- Diagnostic Trouble Code ( commonly referred to as a code here on HT ) PCM- Powertrain Control Module ( same as ECM,ECU,Computer,Brain, people call them many things, most commonly PCM or ECU ) Now, if if feels like a manual, then more than likley your trans is slipping. Your linear solenoid could definatley affect shift patterns. If I were you I would skip all the BS and price a trans or do a 5sp conversion, whichever is more cost effective. I'd recommend taking your car to Honda Dealership and letting them flush your trans with a Honda flush machine, and see if that improves your situation. The linear solenoid is #32 in the picture. http://www.hondaautomotiveparts.com/...ISSION+HOUSING
Hope that helps!
Hope that helps!
you replaced the tranny before trying to swap out the ECU or check the sensors? Also have you reset your ECU since the tranny swap? Most OBD2 Setups remember codes from run to run
I replaced the tranny with a used good tranny.....same code still come on......using my code reader....the code that came up is p0700, p0715 and p1678.....the cluster on the car is a si cluster now not the original one. Would the si cluster play a big role in it....im confuse....im so use to working on manuel transmission not automatic....please advise....
I disconnect the battery for hours and and used my obd2 reader to erase the codes...but once you drive it for about a minute or so, the codes come back up.....throwing check code p0700, p0715 and p1768....confused....i replace the solenoids and it makes no difference....what should i do next....please advise....
wuhungsixxx
Jul 15, 2002 03:45 PM
