Resistor box for 01 integra type R
Old Mar 13, 2011 | 12:21 PM
dcrboost's Avatar
Default Resistor box for 01 integra type R
Good afternoon everyone, I am a new user to this site i have been out of the car scene for awhile now and decided to get back in.That being said i have a question any answers will be greatly appreciated. I own a 01 acura integra type R and ive decided to go boost. i just bought rc 1000 cc injectors and some people are telling me that i need a resistor box for them, is this true.Oh and I am also going obd1. Thanks
Old Mar 13, 2011 | 12:30 PM
92TypeR's Avatar
FSAE
Default Re: Resistor box for 01 integra type R
Welcome.
To be honest, RC-1000's are garbage compared to the new high impedance injectors available these days (ID1000's, FIC, etc).
Do it right the first time. Sell the RC's and buy some new high impedance injectors that do not require the resistor box.
This will allow you to avoid hacking up the OEM wiring, and the ID/FIC style injectors run so much better than the old RC style injectors.
Old Mar 14, 2011 | 09:19 AM
dcrboost's Avatar
Thanks
Old Mar 14, 2011 | 05:24 PM
Kris's Avatar
While he's correct about there being better injectors these days, I wouldn't say you have to hack up the harness or that rc1000s are complete junk. If your injectors are low impedence then you'll need the resistor box and you can get them from almost any obd0 Honda/Acura. It's very easy to wire up, only 5 wires.
Old Mar 14, 2011 | 08:10 PM
dcrboost's Avatar
How would i know if my rc injectors are low impendence? I really dont know much about them.
Old Mar 14, 2011 | 08:23 PM
Kris's Avatar
Do you know if they are peak/hold or saturated? Peak and hold would be low impedance. If you don't know, you can test them with a volt meter, check the resistance on the injector, they should be between 1 and 4 ohms if low impedance (peak/hold) or between 10 and 15 is high impedance (saturated).
Old Mar 15, 2011 | 11:47 AM
dcrboost's Avatar
They are low resistance Peak/hold injectors.
Flow Rate - CC's:
1000 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
95 LBS / HR @ 43.5 PSI
Resistance:
2.5 Ohms @ 68 F
Voltage:
8-15 Volts, nominal 13.5 Volts
Amperage:
Peak 4.0 Amps / Hold 1.5 Amps
Pressure:
Min 30 PSIG / Max 100 PSIG
Old Mar 15, 2011 | 06:09 PM
Kris's Avatar
Yup, you'll need a resister box or some kind of injector driver.
Old Mar 16, 2011 | 10:09 AM
dcrboost's Avatar
What do you recommend i should go with, something economical but that works great
Old Mar 16, 2011 | 06:28 PM
Kris's Avatar
If you want economical then I'd go with the oem resister box..that's what I ran on my crx when I had rc1000s, worked just fine.
Old Mar 17, 2011 | 08:26 AM
dcrboost's Avatar
Do you know where I can find a diagram on how to wire up that oem resistor box?
Old Mar 17, 2011 | 09:08 PM
Kris's Avatar
Found this in the search
https://honda-tech.com/forums/acura-integra-6/resistor-box-wiring-1364840/
Old Mar 18, 2011 | 04:59 AM
dcrboost's Avatar
Thanks that was well made, i tried google but couldnt find anything.
Steeve_Civic
Dec 4, 2011 10:11 AM
b16bri
Sep 5, 2010 02:53 PM
columbushatch
Jan 17, 2009 11:08 AM
the.hamburglar
Aug 12, 2007 07:41 PM
1strdko
Dec 16, 2003 06:38 PM
