no spark no fuel minimi
Old Feb 27, 2011 | 04:51 PM
Blahblah718293's Avatar
Default no spark no fuel minimi
ive got an eg8 with a d15b7 block and a d16y8 head, currently has the stock obd1 ecu in it, and it wont start, i have no spark and no fuel. im suspecting the crank signal because i may have the wrong distributor for that setup. i think im using the b7 distributor but i honestly dont remember which one i put in and i dont know which ones which. i also have a p28 ecu that i was planning on using when i get it running so vtec will work.
can anyone tell me what the right distributor for this setup is, and how to check for crank signal to the ecu?
Old Feb 27, 2011 | 05:00 PM
Former User's Avatar
Default Re: no spark no fuel minimi
Is the G101 ground that attaches to the thermostat housing connected?
Old Feb 27, 2011 | 05:49 PM
the ground on the thermostat housing is connected, has like 5 wires, cant confirm if it is the g101, my haynes doesnt go to 93 civic.
Old Feb 27, 2011 | 05:55 PM
Is 15A hood fuse 31 or 15A dash 24 blown?
Old Feb 27, 2011 | 06:09 PM
yeah thats the ground, and both fuses are good.
Old Feb 27, 2011 | 06:38 PM
How do you know the fuses are good?
Old Feb 27, 2011 | 07:11 PM
test light.
Old Feb 27, 2011 | 07:23 PM
Originally Posted by Blahblah718293
test light.
Good. So you found voltage on both top test tabs of the installed fuses?
When you turn the key to ON(II), do the dash warning lights come on? Does the CEL remain on steady?
Old Feb 28, 2011 | 02:00 PM
cel stays on after the bulb check, yes.
Old Feb 28, 2011 | 02:04 PM
Resolder the main relay.
lott101
Jun 25, 2011 08:53 AM
Youlose1305
14
Jul 29, 2007 07:11 PM
BOMBCRU
Dec 16, 2004 03:47 PM
spaceman
Jul 8, 2004 09:03 AM
B18CRacer
11
Mar 11, 2002 05:09 PM
