95eg/B16A3 - hard to shift in all gears
Old Feb 27, 2011 | 04:07 PM
jdm_phunk's Avatar
Default 95eg/B16A3 - hard to shift in all gears
Just recently while driving when going to shift into *any gear, very difficult to get into gear(does not grind). Doesnt matter what speed(mph)/or what gear. When the clutch pedal is pushed in feels like clutch does not disengage to shift gears, eventually it will go into gear (clutch going out?)
Checked
-clutch master cyl/slave cyl/line for leaks -good
-trans has full fluid-good
-checked shifter bushings/bolts/brackets etc.-good
-clutch is not slipping
-throw out bearing is not making any noise
-clutch/flywheel/master cyl/slave cyl = stock
-have not checked clutch/pressure plate yet
Old Feb 27, 2011 | 04:19 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 95eg/B16A3 - hard to shift in all gears
Does it shift with the car off?
Old Feb 27, 2011 | 04:30 PM
jdm_phunk's Avatar
yes shifts normal with the engine off
Old Feb 27, 2011 | 04:35 PM
The Grumpiest
Check master and slave cylinder. I know you said you checked those but you didn't say how you checked them. It's what happened to me a few weeks ago.
blown_ss's Avatar
try bleeding the slave.
Old Feb 27, 2011 | 04:59 PM
jdm_phunk's Avatar
The master cyl reservoir is full. Had a friend push the clutch pedal to see if the slave cyl is actually moving- good. Ill bleed it when I get home see if that makes any diff there may be air in the lines
Old Feb 27, 2011 | 05:02 PM
jdm_phunk's Avatar
What ended up being the problem? slave cyl?
Old Feb 27, 2011 | 05:07 PM
The Grumpiest
Slave cylinder went bad. But mine just started leaking like a sieve. Same symptoms though so maybe you have air in the system.
Old Feb 27, 2011 | 05:17 PM
jdm_phunk's Avatar
ill be home in an hour, so ill check that out first. Ive got an extra oem slave cyl @ home.
99hondadx
Feb 10, 2017 05:35 AM
flatblack-h22
Transmission & Drivetrain
Jan 18, 2009 05:12 AM
bambbrose
Jul 6, 2005 12:46 PM
ludelvr
Sep 12, 2003 04:20 AM
allmotorls95
Feb 26, 2003 01:30 PM
