LS w/ b16 cable tranny.
Old Feb 19, 2011 | 11:37 AM
codybuRr's Avatar
Default LS w/ b16 cable tranny.
I want to drop an LS/ non-vtec (for now) into my sedan.
but I want to try a B16 cable trans with it.
is that poossible or wut?
Old Feb 19, 2011 | 12:38 PM
B16-CRX's Avatar
Default Re: LS w/ b16 cable tranny.
yes.
Old Feb 19, 2011 | 12:54 PM
Targa250R's Avatar
be professional
Yes.
The clutch you will need depends on the trans you'll be using.
Old Feb 19, 2011 | 08:03 PM
hatchet_honda's Avatar
match the clutch with your trans
Old Feb 19, 2011 | 09:24 PM
hybridmiklo's Avatar
ls with a b16 tranny? No way. thats way too impossible. I don't even think its been done before. You probably are going to need an adapter plate or something. How bout you search before you ask such a basic question?
Old Feb 20, 2011 | 04:17 AM
DeathSquad's Avatar
Simple answer yes.
I currently have a b18a1 obd0 from a 90 Integra.
Ran 15 sec quarter mile on some street slicks for one run, then the tires showed threads. Could have easily broken into 14's.
But its a good first swap, plenty of torque if your a torquey [not a word] guy.
And the douche bag award of H-T goes to the dude from Riverside.
I would expect So. Cal people to be much more friendly to fellow Southern Californians, but it seems my beliefs were wrong.
Old Feb 20, 2011 | 09:20 AM
j3wman's Avatar
yeah douchebag poster is a douchebag. Id say LS on a b16 tranny is a good idea. personally id even go as far as to balance the rotating assembly and get some valve springs and valves so you can get more reliable power in higher RPM since youre gonna find yourself cruising down the highway at 3400 rpm going 70 mph
Old Feb 20, 2011 | 10:15 AM
theft24's Avatar
more like 4000 then 80 is about 4500
Old Feb 20, 2011 | 10:35 AM
codybuRr's Avatar
Hey thanks everyone for the responses.
and of course there is always going to be at least one troll.
nbd.
I just figured it was a quick answer, so no harm in asking.
Also i dont want to convert to hydro.
its just easier for me to have a bolt on cable tranny. thanks guys.(:
Old Feb 20, 2011 | 03:14 PM
Originally Posted by DeathSquad
Simple answer yes.
What do I win? Plus socal is extremely popular area for theft, which is why californians are not exactly that friendly with others just because they drive the same brand of car. and to be useful Y1, (usdm)YS1, trannies use 91 integra clutches. while the japanese ys1 use a hydro ls clutch.
Old Feb 20, 2011 | 03:37 PM
Deetz's Avatar
Crazy Honda Guy
A YS1 is a cable tranny, and uses the same clutch all 1992-2001 B series tranny's. It has a larger mainshaft
The older and 1st gen cable B16 tranny's (Y1,S1) use a small spline mainshaft, same as any B series 1990-91 transmission
Old Feb 20, 2011 | 04:25 PM
jdmboyef9's Avatar
Sarcastic? yes but he does have a point. Someone planning on doing a swap like this needs to do more research before jumping into it. It is not a simple swap, requires custom mounts, linkage, and in many cases wiring. Someone who does not know this need to research more before trying this swap.
As far as Deathsquads useless list of bench racing data, spare us the "coulda, woulda, shoulda". Every motor runs different and personally that's not too impressive.
Now as far as will this work? Yes but it depends on what year and style of B16 tranny you use as stated before. Early model B16A's came with the Y1, S1, and J1 (Deetz you're slipping on me lol) It really doesn't matter though because they are all similar and run the same clutch. In which case these use the same clutches as a usdm 90-91 integra. 92-93 cables were YS1 and use the 92-93 integra clutch.
punxsk8r555
Transmission & Drivetrain
Nov 29, 2010 04:07 PM
blackeg
Jul 11, 2009 06:38 AM
Junkyard
May 15, 2009 09:07 PM
Junkyard
May 14, 2009 09:22 PM
