Clutch Master Cylinder
So the other day when I was driving my clutch peddle went all the way to the floor. Now after looking at it I had come to the conclusion it was my master cylinder and replaced it. Well now that its replaced I am having trouble with the peddle still going down to the floor board.
So does anyone have any ideas of what to check next? The clutch line still good. We bled the clutch line and still have the problem of it going to the floor board. Any ideas on what i need to do or check?
I use this term loosely, but "typically" when a clutch master cylinder is replaced the slave cylinder is also replaced. I would consider changing it out as well.
Are you sure you bled it properly?
Video on replacing honda clutch hydraulics if you want to watch it: http://www.youtube.com/watch?v=c-m5F...layer_embedded
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
