b20 help
Old Feb 12, 2011 | 05:42 AM
92slamed4door's Avatar
Default b20 help
help b20 After I swapped my b20 in to my eg 4 door I noticed that it wouldn't rev past 3000 rpms. It ran fine before in my last 4 door. It's a 95. The car will top out at about 80 mph at 3200 rpm if I don't give it full throttle. If I give it full throttle it will immediately sound like its not getting any gas or maybe spark...
have no check engine i cleared them all.
stuff i did....
tried stock ls ecu
change tps
spark plug
dizzy
fuel pump
fuel filter
oil change
Old Feb 12, 2011 | 05:49 AM
Default Re: b20 help
hellppp me plzzz
Old Feb 12, 2011 | 07:50 AM
toppppppppppp
Old Feb 12, 2011 | 07:55 AM
grumblemarc's Avatar
The Grumpiest
You have the right ECU? That's all I got.
Old Feb 12, 2011 | 07:56 AM
BryanM.'s Avatar
Resident Gearhead
So it did have CEL codes?
Those are to help diagnose the problem.
Sounds like it's in limp, see if codes pop up.
Old Feb 12, 2011 | 08:06 PM
NO CODES POP UP ....
Old Feb 25, 2011 | 09:12 PM
hellppp
Old Feb 26, 2011 | 04:29 PM
eg6king!!!'s Avatar
check ur fuel pressure look at the fuel dampner on the end of the fuel rail mine did the same thing
Old Feb 27, 2011 | 11:03 PM
ill try that tomorrow .......any more helpppp
Old Feb 28, 2011 | 12:30 PM
guyver13's Avatar
up
Old Feb 28, 2011 | 07:58 PM
uppppp
Old Feb 28, 2011 | 09:24 PM
Chilloutdamn's Avatar
map and tps switched on accident? I put my b20 in limp mode that way...
efkilla
Aug 28, 2014 10:09 AM
rexracer626
Jun 24, 2010 06:28 AM
chrisfromsrq
Feb 8, 2010 06:34 PM
K20Ej1
Mar 13, 2006 09:55 AM
11secdx
Dec 26, 2001 08:20 AM
