so if I install my distributor 180 degrees off...
Old 02-28-2011, 06:18 PM
siVix's Avatar
Default so if I install my distributor 180 degrees off...
When I go to install my new distributor and manage to screw it up, as I am prone to do, and stick on 180 degrees out of phase with the cam...when i start it up am I gonna do some damage or will it just not fire?
Old 02-28-2011, 06:29 PM
amej8's Avatar
Default Re: so if I install my distributor 180 degrees off...
What car do you have? I know on the 96-00 Civic models, they purposely designed the distributor and the corresponding grooves on the camshaft so it couldn't be installed 180º off.
Old 02-28-2011, 06:46 PM
lazlong's Avatar
It could backfire out of the intake and you could do some damage to the throttlebody, just depends. Usually the heads are hardened enough for it not to do any damage to them but, again, it depends.
Old 02-28-2011, 06:52 PM
civicsmoke's Avatar
ive done it before when installing a new motor into my car, nothing happened it just wouldnt start obviously.
Old 02-28-2011, 07:10 PM
blackmugensivic's Avatar
nothing, most dizzy's only go in one way, the two tabs are usually offset from the center so they can only go in one way
Old 02-28-2011, 08:48 PM
Syndacate's Avatar
If you can get it on (6th gens aren't symmetric for that reason), it won't start, you'll know real quickly. Just watch the position of the shaft upon removal and insert the same way. If you really want to be sure about it, put a screwdriver in the #1 spark plug hole and turn engine to TDC, then you'll know which way to point the rotor.
Old 02-28-2011, 10:37 PM
siVix's Avatar
Thank you everybody
emu103
10
10-21-2011 07:37 PM
WhiteOnRice
20
01-05-2009 07:50 AM
stRodda
08-09-2004 12:43 PM
davekaro
04-07-2004 06:20 AM
Quick Reply: so if I install my distributor 180 degrees off...
