Lighting HID/Xenon kits, Retrofits and Associated Topics
eg retrofit question
Old Feb 9, 2011 | 05:12 PM
h-o-n-d-a's Avatar
Default eg retrofit question
All the eg retro fits ive seen people use the clear lense blacked out headlights. would it matter if i used the oem lights with glass fluted lenses? I realize it would effect everything coming out of the headlamp and is the main reason why others use the cheap aftermarket lights. but i hate the way the black retro headlamps look. any ideas?
Old Feb 9, 2011 | 08:24 PM
prelude1897's Avatar
Default Re: eg retrofit question
the reason for using clear lenses is to provide a better, brighter light output. If you use your glass lenses, you're going to cut down on the light output, cause if you thinking about it, the bulbs have to shine through 2 glass lenses(projector lense and headlight lense) If you don't like the blacked out look, you could always paint them
Old Feb 10, 2011 | 09:10 AM
xunsungheroesx's Avatar
The reason for using clear lens is because the stock glass lens is fluted thus it would distort the projector beam pattern. Black housing is generally used 1) to minimize any reflection of light off of the housing and thus reduce glare; 2) because it's aesthetically pleasing.
tasco
Lighting
Jul 9, 2011 05:50 PM
EJ2-Fluffy
Apr 4, 2008 07:55 AM
civicsareslow
10
Sep 11, 2005 03:20 PM
92ehatch
Jul 22, 2005 11:53 AM
