Just got a chipped( not going to mention name out of respect for a vendor)ecu
Old Feb 8, 2011 | 10:23 AM
350znal's Avatar
Default Just got a chipped( not going to mention name out of respect for a vendor)ecu
See if some of you guys can point me in the right direction or the sponsor on here for said company.
I've been running a stock jdm p13 ecu since i got the car(h22a swap in a 99 cx). Only codes i get are a iab and egr. It takes alittle bit of driving before these even come up. Car pulls strong with this ecu, just seems alittle rich. Also falls out of vtec on the 1/2 shift.
I put in the chipped ecu today. The idle is surging and then throws a iacv cel. Anything under part throttle below 2k and it surges. When i accelerate and let off it jerks and does the same when i get back on the accelerator. After 6k it feels like the power band just plateaus.
I used the same spot far as distance and ran both computers. The chipped one ran about 75/6 mph and the p13 ran 80 mph( even though it falls out of vtec).
Could the p13 have been chipped? Could the tps voltage be incorrect?
Any info would be helpful.
Old Feb 8, 2011 | 11:14 AM
HRTuning's Avatar
Default Re: Just got a chipped( not going to mention name out of respect for a vendor)ecu
The P13 can be chipped, so you may want to check. Either way a basemap isn't going to get you perfect... but tuning will.
Old Feb 8, 2011 | 01:39 PM
350znal's Avatar
talked to said vendor. He thinks the iacv driver may have failed. The rest he doesn't know till he gets the ecu back..
Thanks vendor for the phone call.
Old Feb 8, 2011 | 05:48 PM
HAMOTORSPORTS's Avatar
Glad to hear that HT vendors are taking care of their customers. Maybe there still is a few legit shops around
... As far as the power falling off on the top end, you still should have your car tuned. A basemap is just that, a BASEmap.
Old Feb 9, 2011 | 09:00 AM
93turbo16's Avatar
I have had to repair a few IACV circuits in the past, they generally go bad when you mix up the IACV/EVAP/IAT plugs.
It usually fries two of the resistors and the transistor right above it and is generally a simple fix.
Old Feb 9, 2011 | 09:10 AM
2k.civic.si's Avatar
why would you buy a chipped ecu with basemap and then go drive the car hard?
Old Feb 9, 2011 | 05:40 PM
350znal's Avatar
My car is running off a stock p13 ecu. Only has intake and exhaust. The basemap shouldn't be that much different from the p13, so i wasn't worried about running it hard.
The p13 doesn't show the iacv cel.
Old Feb 9, 2011 | 06:14 PM
HRTuning's Avatar
The basemap would be very different from the P13, as the P13 maps don't transfer over to other platforms.
EGhatch-dueceX2
Apr 2, 2012 08:20 AM
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
Woogie Ctr
Apr 20, 2006 06:07 AM
Acura_I-RS
Oct 30, 2005 09:06 AM
andreysibiris
Jul 31, 2005 02:44 PM
