odometer stuck on Si cluster
Old Feb 7, 2011 | 07:44 PM
pliskin8's Avatar
Default odometer stuck on Si cluster
the odometer is stuck on my 99-00 si cluster, is there any simple way of fixing this (i have'nt done anything to it yet) it's been like that since i bought it a couple months back
Old Feb 7, 2011 | 08:05 PM
MagnaniEG6's Avatar
Default Re: odometer stuck on Si cluster
This happen to my eg6 cluster so I pulled the need off, pulled the face plate and with a tooth pick or small flat head screw drive roll it to the next set of numbers so mine was stuck a 39,999KM-between 40,000KM after that drove around and it was fine.
Old Feb 7, 2011 | 08:25 PM
pliskin8's Avatar
thanx, i did'nt want to f-it up even worse with without knowing what to do
Old Feb 7, 2011 | 09:55 PM
djslim23's Avatar
idk if you want to change that, lol, that's a good selling point if you ever get rid of it
Old Feb 7, 2011 | 10:27 PM
pliskin8's Avatar
lol! only 99 miles!!!
Old Feb 7, 2011 | 10:44 PM
beeseeries's Avatar
Push the maintenance reset button with your key and the trip button at the same time.
Old Feb 8, 2011 | 02:34 AM
BlueIntegraBoy's Avatar
Looks like who ever had it last tried to roll back the miles.
Remove the speedo from the housing and check behind it. Use a small flathead to pry the metal bar from the clip closest to the "lower mileage" numbers behind the odo. Make sure all the small gears are lined up properly along with the numbers in the front. Then push back the metal bar
Old Feb 8, 2011 | 03:39 AM
NVturbo's Avatar
O.G. triple O.G.
the way the digits appear......the speedo looks like it was "turned" back. Anyone else agree?
Old Feb 8, 2011 | 09:14 AM
beeseeries's Avatar
Now that you mention it, they do. I just assumed they were stuck.
Old Feb 8, 2011 | 09:48 AM
JdmCoupe91's Avatar
Yea... When you pry off the needle place something underneath the screwdriver (( or whatever you're going to use to pull the needle off )) so that you don't scratch the face of your speedometer. A piece of paper works.
Old Feb 8, 2011 | 10:22 AM
You don't need to pry the needle off.
OP: Read my directions above. PM if you have any questions.
Old Feb 8, 2011 | 07:53 PM
pliskin8's Avatar
ok, i'll give it a shot tomorrow, i still havent done anything to it yet
Old Feb 18, 2011 | 05:57 PM
GIL7198's Avatar
Have you tried it yet i just got a cluster that is stuck too LMK asap..
Old Feb 19, 2011 | 06:36 AM
eghatch4sale's Avatar
ummmm ya dont listen to these people about pulling the needle off !!!!!!!!!!! whoever you got the cluster off of most diffenetly tried to roll the miles back ...... there is 4 tiny phillips screws on the back of the odometer take the plastic covers off undo the screws and that will remove the odometer and u can inspect it to see why it is not working
SpeedoKing
Jun 26, 2008 04:47 PM
01-0720
Jan 24, 2008 10:03 PM
kleanlscivic
23
Nov 15, 2004 06:57 AM
trigga
11
Nov 2, 2003 08:27 PM
B96v6
17
Aug 2, 2002 10:43 PM
