1995 coupe, rad fan not turning on
Old Feb 5, 2011 | 11:13 AM
Slayer85's Avatar
Default 1995 coupe, rad fan not turning on
The cooling fan is not kicking on.. Swapped relays around being that its an a/c car and its still not working... could this be a bad fan? please let me know asap its on my buddy's car
Old Feb 5, 2011 | 12:04 PM
Former User's Avatar
Default Re: 1995 coupe NEED HELP!!!!!
Unplug the 2-wire fan switch on the thermostat housing and then jump the connector with a paper clip or short piece of wire. Does the fan now run with the key in ON(II)?
Old Feb 5, 2011 | 01:00 PM
95ProjectEJ1's Avatar
^^^ Go go go and let us know what you find...
Old Feb 6, 2011 | 02:04 PM
Slayer85's Avatar
yep it works! is it the Coolant temp sensor thats bad?
Old Feb 6, 2011 | 03:02 PM
First try bleeding the cooling system before replacing the ECT switch.
Old Feb 6, 2011 | 09:49 PM
Slayer85's Avatar
Default Re: 1995 coupe, rad fan not turning on
Well the system has been bled and its still not kicking on... He went ahead and replaced the ECT and its still not working, But the paper clip is lol
Old Feb 6, 2011 | 10:11 PM
ej2kiid's Avatar
i put a fuse on the plug for the fan and works fine...
Old Feb 7, 2011 | 04:48 AM
Sounds like you have not bled all of the air from the system.
Old Feb 7, 2011 | 09:24 AM
Slayer85's Avatar
Ok so now the Lower Coolant Hose is staying cold... Bad thermostat?
Old Feb 7, 2011 | 09:25 AM
Old Feb 7, 2011 | 09:43 AM
Slayer85's Avatar
Theres no air in the system its not gargling like theres air in the system.. So would this mean that the T-stat is staying closed???
Old Feb 7, 2011 | 10:08 AM
You won't know if there's air trapped in the cooling system until you do a thorough bleed. A bad thermostat could also cause the symptom you are having, although in this case the engine would overheat and the radiator fan would turn on.
Old Feb 7, 2011 | 10:16 AM
SeanK325's Avatar
it wouldn't kill you to just bleed the system again, too. coolant/water is cheaper than a new OEM t-stat.
Old Feb 7, 2011 | 11:30 AM
Slayer85's Avatar
well bleeding the system again didnt do it... replaced the t-stat and now its working... thanks for input guys....
skyeboy
17
May 18, 2013 07:15 PM
jlowellintegra
May 30, 2011 07:52 AM
Neo218
Apr 5, 2010 07:15 PM
Rayz_Si
13
Feb 27, 2008 08:29 PM
ATS*Mark
Dec 9, 2003 11:08 PM
