d15b7 no spark at dizzy
ok i cannot get spark to my dizzy. i checked main relay someone had it bypassed for some reason i checked in in another car its good. so i reconnected the wires that was bypassed. the dizzy itself is brand new... ecu is good. can hear fuel pump running. any leads??? what are some wires i can put a volt meter on on the dizzy wires to check if the wires are good?
Re: d15b7 no spark at dizzy
You don't get spark to the dizzy it comes from the dizzy.
It sounds like it could be your coil or igniter,a common problem on Hondas.
If the engine is run or cranked with one or more plug wires disconnected, the coil may blow. Did you possibly do this? If not, do the igniter unit input tests (see FAQs sticky). Also check the Yel/Grn wire, which runs from the igniter unit to the ECU, for an open or short.
If all above is fine, then swap in a known good ECU.
408wdy
05-12-2007 01:29 PM
Ron Burgandy
05-07-2007 11:19 PM
