is it my fan switch????
OG triple OG
ok im having cooling system problems.....my car wants to overheat....i replaced the thermostat because the fan eventually would turn on and the car would cool down , so i thought my thermostat was it . but if my fan isnt turning on when its supposed to , is it the fan switch thats bad???
Re: is it my fan switch???? (Hella_JDM)
is it not turning on when its supposed to? or is it not turning on at all? if its not turning on when it supposed to i would check into the coolant temp sensor. if its not turning on at all, check the fan itself. also when u filled the car back up with coolant after replacing the t-stat, did u let the radiator burp itself?
OG triple OG
Re: is it my fan switch???? (Grimace EJ6)
ya i let it burp its self....the fan will eventually come on but when the car is already very hot when it does.....
Hmm, I had a similar problem, but the fan would barely ever turn on, it ended up being the switch. For the time being, it was hard wired, and it was constant. But it was the switch that failed.
OG triple OG
Re: is it my fan switch???? (rodrez)
welll , thanks to autozone for selling me 2 bad thermostats....i rigged tthe fan to be on all the time this morning to see if in deed it was the fan switch....which in the end i think it was.....but i bought a thermostat at autozone ,installed it , lower hose was cold , not luke warm , but cold , so i took it out and got another one , faulty too!!!! so i got another one , and now it works perfectly
hotcivicsi
19
05-15-2009 01:54 PM
kai-chun
12
09-08-2006 03:20 PM
B_1_8_hatch
01-23-2003 07:03 PM
