Help needed!! e brake lights is on
Old Jan 30, 2011 | 10:55 PM
Fishyboi4's Avatar
Default Help needed!! e brake lights is on
Hi there guys well let me start by saying that im a noob to this and I drive a 1993 Honda del sol si and about 3 days ago my emergency brake light keeps turning on. Im not low on brake fluid either, I checked. But could it possibly be that my rear brake are still locked on? By the way my rear brake are disc brakes not drum and I haven't checked but my rear disc brakes theyve been also making squeaking noises, which would mean that it's out but I was just wondering if it would be possible that my rear brakes are still slightly lock. I know I should check it out first but, haven't gotten the spare time to look at it. But please any help would be appreciated.
Old Jan 31, 2011 | 01:50 AM
Deviant117's Avatar
Default Re: Help needed!! e brake lights is on
Does the light go off if you hit the brake pedal pretty hard while driving? I live in northern Indiana and love to e-brake in the snow. Now when I accelerate, the light comes on, I hit the brakes and it goes back off. Doesn't give me problems in the summer though.
Old Jan 31, 2011 | 05:09 AM
Former User's Avatar
Could be a problem with the float and switch in the brake fluid reservoir.
Old Jan 31, 2011 | 05:19 AM
andyz's Avatar
Check this:
Brake warning light indicates parking brake is engaged and/or brake fluid level is low. To adjust parking brake light operation, turn ignition on. Bend switch plate down until light comes on when parking brake lever is pulled one notch and goes out when lever is released.
Old Feb 1, 2011 | 09:02 AM
Fishyboi4's Avatar
well the brake light only comes on when i start my car and after driving it for like 15 mins. it'll go off but sometimes it doesnt come on at all until i step on the brake pretty hard and it'll come back on. Also my parking brake leverage isnt on either when im driving, it's pushed down all the way.
Old Feb 1, 2011 | 09:20 AM
Be sure to check the float and switch in the reservoir.
Old Feb 1, 2011 | 09:45 AM
gsrekrevs210k's Avatar
Have you checked the actual sensor under the e-brake handle? is that the light youre talking about? the one that comes on when you pull the ebrake? if thats the case then it sounds like your e-brake handle isn't going down all the way and pushing the sensor switch in all the way.
Kdeezy95
11
Nov 10, 2013 10:20 PM
X01Michael
Jan 10, 2011 11:48 AM
Vanadium
Mar 7, 2008 03:26 AM
donniebrasco
Oct 5, 2004 07:43 AM
99PreludeSH99
Dec 13, 2003 09:11 AM
