Car wont start?
96 prelude bone stock. Drove fine the other day, but the next morning the car wont start. I checked the spark and it seems like it not getting any. The plugs where wet with fuel so I guess it's getting fuel. So I ruled out fuel. Pulled the plugs out hooked up the spark wires and grounded the plug to see if there is any spark but nothing. I change the ignition coil, rotor & cap, ICM. The plug and plug wire are fairly new about 6 months old. I have no more ideas what it can be. You guys think it could probably be crank angle sensor?
Can the crank position sensor cause the spark not to fire? What others on the vehicle can cause these kind of symptoms? Is there anything else that I should be checking for? Any help is appreciated.
Diyracing2
Jan 2, 2007 07:43 AM
