IACV???
Old Jan 2, 2011 | 04:42 PM
metalmulisha87's Avatar
Default IACV???
i got a code saying dat my IACV failed? does this mean my car aint starting? the car is a 96 civic lx...
Old Jan 2, 2011 | 09:25 PM
virgineg6's Avatar
Default Re: IACV???
wow
Old Jan 2, 2011 | 10:27 PM
98corbeau coupe's Avatar
Default Re: IACV???
its means yer idle air control valve is bad or dirty... your car will start but idle like ****...if u wanna buy one i have one off my 98 d16y8 pm me and i can hook u up
just so u knwo they r around 200 new so buying a used one is def worth it
Old Jan 2, 2011 | 11:45 PM
evilclown312's Avatar
Default Re: IACV???
If i remember correctly i was quoted around 230 from autozone...
Old Jan 3, 2011 | 11:50 AM
dj-bilbo's Avatar
Default Re: IACV???
OP: IACV and FITV (depending on year model) are common source of problems. Before u spend $250 on a new one, take yours out, clean it with brake cleaner or similar item. let it dry completely. put it back on and see if that helps. Similarly, if you are close to a junkyard, finding a used one and cleaning it can be a solution that will cost u less than buying a new one. If all fails, then suck it up and get OEM one.
good luck! Tons of DIY on the net for how to replace/clean IACV or FITV causing idle surge
Old Jan 3, 2011 | 12:15 PM
Red_Army's Avatar
Default Re: IACV???
^^and its super easy.
Old Jan 3, 2011 | 12:57 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: IACV???
unless your car is an auto its not compatible with his
Old Jan 3, 2011 | 01:50 PM
MonkeyMagic's Avatar
Default Re: IACV???
they are free at most junk yards
or if you pay for them.. probably ten bucks.
Originally Posted by virgineg6
wow
qft
Old Jan 3, 2011 | 03:13 PM
blackoutt2000's Avatar
Default Re: IACV???
They get dirty, especially if your car was/is running rich for some reason. Take it off and clean it with carb cleaner.
Old Jan 4, 2011 | 10:32 AM
Default Re: IACV???
yea i cleaned it but car aint starting so i dont know if it runs lik crap? its been snowing and never got a chance to get to the car...i also got a code saying dat the intake air has an high input?
Old Jan 4, 2011 | 01:22 PM
Former User's Avatar
Default Re: IACV???
There's more than one IACV code. Which do you have? An IACV code does not necessarily indicate an IACV problem.
An IACV or IAT code would not prevent the engine from running. Is this a no-crank or no-start problem? If the starter cranks the engine, do you have spark and fuel?
Old Jan 4, 2011 | 02:25 PM
Default Re: IACV???
the code said that i had a IACV failure...the car cranks over but no start i do got spark but not sure bout fuel havent gotten a chance to miss wit the car since its been snowing...could a bad Fuel pressure regualtor be a problem
Old Jan 4, 2011 | 03:19 PM
Default Re: IACV???
Again, what was the specific CEL code? No CEL codes specifically indicate an IACV failure. Some indicate a problem in the IACV circuit (IACV, wires, or ECU) while others may indicate a bad IACV, vacuum leak, bad ECT/circuit, bad TPS/circuit, or a misadjusted idle speed.
Is spark bright white at all 4 spark plugs? Do you hear the fuel pump prime?
Old Jan 4, 2011 | 07:05 PM
Default Re: IACV???
the code is: p1509 IAC Valve Circuit Failure...yea i got all 4 sparks and the fuel pump does prime...
Old Jan 4, 2011 | 07:08 PM
Default Re: IACV???
Check whether the IACV plug gets battery voltage and also whether the IACV wires have a short or open. If all this is fine, then the ECU may be bad.
If spark is bright white and the fuel injectors spray fuel, then check the mechanical timing.
Old Jan 4, 2011 | 07:14 PM
Default Re: IACV???
okay well do...u know how much a ECU runs for? but im thinkn of doin a swap?
95gsr@530
May 13, 2019 10:43 AM
aaronfunstuff
Feb 15, 2014 03:09 PM
lrcrx90
Aug 22, 2010 02:16 PM
juan3023
Apr 29, 2009 08:54 AM
ridin98civic
Dec 28, 2007 01:45 PM
