IACV???
Re: IACV???
its means yer idle air control valve is bad or dirty... your car will start but idle like ****...if u wanna buy one i have one off my 98 d16y8 pm me and i can hook u up
just so u knwo they r around 200 new so buying a used one is def worth it
Re: IACV???
If i remember correctly i was quoted around 230 from autozone...
Re: IACV???
OP: IACV and FITV (depending on year model) are common source of problems. Before u spend $250 on a new one, take yours out, clean it with brake cleaner or similar item. let it dry completely. put it back on and see if that helps. Similarly, if you are close to a junkyard, finding a used one and cleaning it can be a solution that will cost u less than buying a new one. If all fails, then suck it up and get OEM one.
good luck! Tons of DIY on the net for how to replace/clean IACV or FITV causing idle surge
Re: IACV???
yea i cleaned it but car aint starting so i dont know if it runs lik crap? its been snowing and never got a chance to get to the car...i also got a code saying dat the intake air has an high input?
Re: IACV???
There's more than one IACV code. Which do you have? An IACV code does not necessarily indicate an IACV problem.
An IACV or IAT code would not prevent the engine from running. Is this a no-crank or no-start problem? If the starter cranks the engine, do you have spark and fuel?
Re: IACV???
the code said that i had a IACV failure...the car cranks over but no start i do got spark but not sure bout fuel havent gotten a chance to miss wit the car since its been snowing...could a bad Fuel pressure regualtor be a problem
Re: IACV???
Again, what was the specific CEL code? No CEL codes specifically indicate an IACV failure. Some indicate a problem in the IACV circuit (IACV, wires, or ECU) while others may indicate a bad IACV, vacuum leak, bad ECT/circuit, bad TPS/circuit, or a misadjusted idle speed.
Is spark bright white at all 4 spark plugs? Do you hear the fuel pump prime?
Re: IACV???
If spark is bright white and the fuel injectors spray fuel, then check the mechanical timing.
juan3023
04-29-2009 08:54 AM
ridin98civic
12-28-2007 01:45 PM
