single layer head gasket
Old Dec 29, 2010 | 06:30 AM
dc4teg95's Avatar
Default single layer head gasket
how much will a single layer head gasket raise compression? im rebuilding my usdm itr block(rings, bearings etc) and been thinking bout doing a single layer head gasket. also which layer would i use the upper or lower layer?
Old Dec 29, 2010 | 07:57 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: single layer head gasket
For every layer you remove, you bump compression by approx .2. You can use either the top or bottom portion. I'm running the same thing now.
Old Dec 29, 2010 | 11:51 AM
dc4teg95's Avatar
So removing the top and middle layer I would be raising it .4
Old Dec 29, 2010 | 12:06 PM
00Red_SiR's Avatar
All Motor Mentor
yes, any 2 layers removed.
Old Dec 30, 2010 | 01:08 PM
hybridnorth's Avatar
No problems with it leaking or anything? Are you using head studs or OEM hardware?
Old Dec 30, 2010 | 03:44 PM
00Red_SiR's Avatar
All Motor Mentor
No problems. I did use some copper spray on both sides as a little added insurance though. I use factory headbolts which are all that is needed for 99% of the builds you'll see on here.
Old Dec 31, 2010 | 03:55 AM
Garrett's Avatar
I have some doubt, about using only 1 layer gasket longevity
Old Dec 31, 2010 | 09:23 AM
ddd4114's Avatar
I dunno, in my opinion, hackjob head gaskets aren't worth it. You're taking a risk for what, 1 hp? Maybe 2 for a low-compression engine that already makes a lot of power?
Old Dec 31, 2010 | 05:44 PM
00Red_SiR's Avatar
All Motor Mentor
If it's done properly, I wouldn't call it a hack job and the risk would be little more than a HG failure. I went with a single layer to help get my compression ratio to the range I needed for the cams I was running. I didn't want to go into the block to change pistons and the headwork I had done, only got me down to 42cc chambers so I had to go with a single layer gasket and I was still a little lower than I wanted.
rmcdaniels
Nov 23, 2005 11:45 AM
Little Rascal
Jun 8, 2005 07:18 AM
CoreyR
Sep 22, 2004 11:02 PM
.::Lee::.
Feb 17, 2004 08:50 PM
