d16z6 axle seal #?
ok what seal are you after?
the seal for the axel shaft to tranny
A/Trans & M/Trans Output Shaft Seal - Left (Drivers Side)
Product Line: NAPA Oil Seals
Per Car Qty.: 1
P/N: NOS 14006
M/Trans Output Shaft Seal - Right (Passenger Side)
Per Car Qty.: 1
P/N: NOS 15989
A/Trans Seal, Output Shaft - Right (Passenger Side)
Per Car Qty.: 1
P/N: NOS 13849
If crossing this nuber at different Parts store other then NAPA remove the NOS from the part Number.
The Drain plug uses a standard DRAIN PLUG (14MM) Gasket found at Most parts stores
The filler plug uses a standard DRAIN PLUG (20MM) Gasket found at Most parts stores
Per Car Qty.: 1
P/N: NOS 14006
Per Car Qty.: 1
P/N: NOS 15989
Per Car Qty.: 1
P/N: NOS 13849
I have seen alot of "oem" online parts places list 91205-pl3-a01 for the Passenger & Driver side but none of the Interchange books i have list that as a good number.
Also i have done the Output shaft seals in my 95 Del Sol twice and there not the same seal. on both sides
Driver side Seal Specs
T/Axle Output Shaft Seal I.D. : 1.339"
T/Axle Output Shaft Seal O.D. : 2.218"
Passenger side seal Spec
T/Axle Output Shaft Seal I.D. : 1.575"
T/Axle Output Shaft Seal O.D. : 2.452"
the part #'s that keep coming up are
91205-PC9-711 & 91205-PL3-A01
the PC9-711 is bigger then the PL3-A01 Seal but i can't get eather number to Crossover to any other seal number but i was able to find out that honda OEM seals are Made By CR seals and thats the same company that makes the seals for NAPA
For something like a trans seal, where the size is pretty important and if it's bad, you probably won't know until it's too late, why not just buy OEM? I was going to order some a while back and they weren't expensive.
i was asking because i have brakes and suspensions class and was thinking of doing my car in class tomorrow. my ball joint and putting a new cap to seal my d/s axle right because it's been leaking. i bought the oem honda cap part no. 91205-pl3-a01, but not sure if it'll fit because the numbers always change... so, was double checking.
I see well best thing i can tell you is if it is the wrong seal you will know right away there's a big difference in the way thay look.
also when i was in high school i would work on my acr in shop all the time and if i ended up with the wrong part the local parts store was more then happy to bring me the right one and thay didn't do deliveries.
Iloveyourhonda92
Apr 15, 2012 08:29 PM
kdsmonitor
Mar 7, 2009 04:00 PM
