D16Z6 Transmission Oil seal replacement?!
So my oil seal leaks(located right where the driver side axle goes into the transmission). I was wondering if i have to pull the transmission apart to replace this seal because of the metal backing or if i can pull the axle and just pull the seal right off and drive the seal in without having to take off the transmission, any links or answers to my questions would be greatly appreciated!
Re: D16Z6 Transmission Oil seal replacement?!
Yep, pop the axle out. Pull the old seal out, then try to find a socket that's the exact size of the metal ring on the outside of the seal tap the socket with a hammer to push the seal in. Make sure it's seated properly and even.
Thanks guys, helps alot. I just pulled the transmission and reassembled it yesterday, i really didnt wanna have to take it off again!
Emeraldbomber
14
09-19-2012 04:04 PM
OldMrAccord
11-24-2010 02:27 PM
Former User
05-27-2010 10:52 AM
