Garrett T61/ Gt40 Blowzilla 35r Compressor Wheel
Old Nov 22, 2010 | 02:37 PM
Hondaruss's Avatar
Default Garrett T61/ Gt40 Blowzilla 35r Compressor Wheel
t61/gt60 Garrett turbo In great shape no shaft play no damage barely used turbo. Come with 4 bolt .63 exhaust housing with a bolt on v band adapter. I am going to a 6262 instead Specs are below..
This is a special order turbo from Garrett. Cost from Garrett is around $880+
Asking 600 shipped
Garrett T61 (samecompressor wheel as GT35R aka GT3540R) Turbo with P trim or Stage 3 turbine wheel and T3 (Specify) A/R turbine Housing. This is a journal bearing unit with oil cooling only - Garrett factory assembled and balanced.
Compressor Specs: GT40 (same compressor wheel as GT35R aka GT3540R)
.70 a/r Comp. Housing 4" inlet / 2.5 outlet
61mm inducer/ 82mm exducer
flow: 65 lbs/min 832cfm
Turbine specs: T3
Turbine wheel: P-trim / Stage 3
360* thrust bearing standard
Old Nov 22, 2010 | 08:57 PM
Hondaruss's Avatar
Default Re: Garrett T61/ Gt40 Blowzilla 35r Compressor Wheel
ttt
Old Nov 22, 2010 | 09:08 PM
carbon fiber coupe's Avatar
how much hp is this rated for?
Old Nov 23, 2010 | 08:00 AM
Hondaruss's Avatar
you have a pm
Old Nov 23, 2010 | 01:28 PM
Hondaruss's Avatar
ttt
Old Nov 24, 2010 | 03:20 PM
Hondaruss's Avatar
ttt
Old Nov 25, 2010 | 10:49 AM
Hondaruss's Avatar
Turkey day bump
Old Nov 26, 2010 | 04:40 PM
Hondaruss's Avatar
ttt
Old Nov 28, 2010 | 03:55 PM
Hondaruss's Avatar
ttt
SpiderSol
Oct 17, 2005 04:55 PM
done
Mar 10, 2005 08:58 AM
Mr. JDM-GSR
Jul 11, 2004 11:43 AM
ArchAngel Sabastian
Jan 4, 2004 10:46 PM
specie
Jan 15, 2003 06:15 PM
