00 Civic DX auto -- Idle problem re-arose...
Old Nov 13, 2010 | 10:11 PM
See-Tee-R's Avatar
Default 00 Civic DX auto -- Idle problem re-arose...
So two weeks ago, I had an idle problem. (I dont have a tachometer, so I dont know exactly how many RPMS) Basically the idle went up and down as if I was holding down the gas and letting go continuously. A Check engine light popped up and I got the code, It happened to be a IACV. So I cleaned my IACV, everything worked perfectly, fixed the idle problem, and CEL went away.
Heres the bad news... So I find out that I'm leaking oil under my distributor, and research tells me that it is my dizzy leaking the oil. So I mark the dizzy with a screw driver, remove it, change the o-ring but in the process I accidentally flipped the fin (part that goes into camshaft) so basically I figured that since it can only go in 1 way, I switched it into position and put it back in (Is it possible that the turning of the fin can affect my idle?). Lined up my bolts for the dizzy and tightened everything up. I tried to start the car, and no crank, turned out to be a dead battery, so I replace the battery, and now it starts.
The problem is that the idle problem is back, and worse than before. What is the problem now? Vacuum leak? IACV AGAIN? Dizzy? That fin inside the dizzy? timing? battery?
Car: 2000 Civic DX Hatchback
Engine: D16Y7
Transmission: Automatic
Please help me out asap, this car is my daily driver, and Im pretty lost without it. If all else fails, Im gonna have to bring it into the dealership
Old Nov 14, 2010 | 04:11 PM
See-Tee-R's Avatar
Default Re: Idle problem re-arose...
bump?
Old Nov 14, 2010 | 05:22 PM
Former User's Avatar
CEL codes?
Disconnected vacuum hose?
Old Nov 14, 2010 | 08:51 PM
See-Tee-R's Avatar
Default Re: 00 Civic DX auto -- Idle problem re-arose...
Theres no CEL as of right now. There was before I cleaned the IACV and Throttle body, and then the problem went away as stated, It wasnt until I messed with the Dizzy that the problem resurfaced.
Im not sure where the vacuum hoses are located... Could you point me in the direction? and I dont see how it could be disconnected either...
Old Nov 15, 2010 | 04:43 AM
Vacuum hoses:
Old Nov 15, 2010 | 07:07 PM
See-Tee-R's Avatar
Alright thanks for the diagram. However, Something stranged happened... today my Check Engine Light popped up, I checked my code, and it popped up 14, the IACV. Strange because I just cleaned it, along with the throttle body. Now heres where it gets even trickier. I unplug the fuse for FI E/M and the backup radio fuse to reset the ECU and guess what... No idle surging..... Could this fix be temporary? any ideas? Im stumped
Old Nov 15, 2010 | 07:11 PM
If the problem returns, as it likely will, check whether unplugging the IACV affects the idle speed. Also pull the code with a code reader to get the OBDII CEL code.
Old Nov 15, 2010 | 07:14 PM
See-Tee-R's Avatar
Alright, Well Im gonna drop it off at the Honda dealership and see if they can sort it out.
Thanks for the help Ron
LST2
Jun 24, 2008 11:53 AM
revhardEK
May 30, 2008 02:34 PM
peterislazyek9
Jan 26, 2008 08:47 PM
jaycapz
Sep 1, 2004 02:43 PM
EddieHatchBlack
Dec 6, 2002 12:10 AM
