dipstick problem
Old Oct 28, 2010 | 06:19 PM
tegra1027's Avatar
Default dipstick problem
I have an ls/vtec turbo. My problem is that the manifold is a log and is blocking the dipstick. Making it pretty much impossible to check the oil. Has anybody encountered this problem before? Any suggestions to fix this? Thanks!
Old Oct 28, 2010 | 06:26 PM
LightningTeg's Avatar
Community Builder
Default Re: dipstick problem
You dont want to run no dipstick. You'll shoot oil out on the manifold when boosting. Ask me how I know...
Old Oct 28, 2010 | 07:04 PM
Silva Bullit DC4's Avatar
What brand & design log manifold do you have? Post up a quick pic.
Old Oct 28, 2010 | 07:29 PM
2k.civic.si's Avatar
get a better manifold that doesnt block it.
Old Oct 29, 2010 | 06:29 AM
tegra1027's Avatar
I cant remember the brand... And actually im not even sure this is considered a "log" manifold.
Old Oct 29, 2010 | 08:17 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
You can bend it to make it work.
Old Oct 29, 2010 | 09:52 AM
tegra1027's Avatar
Thats what I was thinking, does the dipstick tube come out of the block? If I do do this, I should prob do an oil change and then mark the dipstick where the oil level should be... What do you think?
Old Oct 29, 2010 | 10:27 AM
lsef's Avatar
Maybe if you grind down the webbing it might fit and fyi the oil level should not reach the dipstick.
Old Oct 29, 2010 | 10:44 AM
Community Builder
Just bend the handle portion out to the left under the manifold.
Old Oct 29, 2010 | 11:25 PM
tegra1027's Avatar
I dont quite understand. There are markings on the dipstick already to show where the oil level should be. That is the point of the dipstick in the first place... Am I wrong?
Lightning- i can bend the handle, I just cant get the dipstick back in the tube once its out... So that wont really do anything.
Does anybody know if and how the dipstick tube comes out?
Old Oct 30, 2010 | 02:30 AM
Tony the Tiger's Avatar
If you are really having trouble, twist the oil dipstick tube (the tube that goes into the block) to a different rotation and you can have the dipstick opening facing on one side (either beside the power steering or beside the distributor). You can also take that tube out and bend it slightly if you need a steeper angle.
Old Oct 30, 2010 | 02:39 PM
tegra1027's Avatar
ok so it comes out then...... how does it come out? Is it threaded in?
Old Oct 30, 2010 | 03:40 PM
Garage 808 Hatch's Avatar
It's pressed in. Pretty tight fit
Old Oct 30, 2010 | 11:25 PM
samuraijackass's Avatar
I'm running a blox manifold which is similar. I would grind out that webbing and get a shallow headed bolt for the center of the manifold to free up some space. You will still probably need to bend the top handle portion of the dip stick to keep it out of the way.
Old Oct 31, 2010 | 06:18 AM
fcluddington's Avatar
I have very simular manifold i just bended the dipstick tube and it will bend a lot. i also put a slight bend on the thin wire portion. I went towards the ps pump so it sounds like it goes either way. aka a bi bent dipstick. lol
1sick4dr.
Jul 20, 2007 10:19 AM
AlpineIntegra01
Aug 17, 2005 07:02 PM
CaptainMorgan
Jan 18, 2004 10:38 PM
ScrapinSi
Jun 13, 2003 06:09 AM
xpracing
Jan 15, 2003 09:10 PM
