Idle jumps to 2500 rpms after start up
Old Oct 16, 2010 | 07:55 PM
bLu92bUbbLe's Avatar
Default Idle jumps to 2500 rpms after start up
after shes been sitting for a long time and i go to start her up...the idle jumps up to 2500 rpms....how do i adjust this....
Old Oct 17, 2010 | 08:15 AM
Former User's Avatar
Default Re: Idle jumps to 2500 rpms after start up
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
If you hope to get useful replies, then provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please familiarize yourself with the stickies at the top.
Old Oct 17, 2010 | 02:55 PM
civiclx1988's Avatar
after your car sits for awhile your battery is going to drain and when you start it you alt. is going to make your engine idle speed higher till it charges the battery back to normal than drop down to 6-800 rpm if this isn't your case you can adjust the throttle cable and back it off.... or mess with the idle adjustment screw on your tb....
Old Oct 17, 2010 | 03:24 PM
Targa250R's Avatar
be professional
A fast idle on cold start-up is normal. As long as the engine slowly returns to a normal idle as the coolant warms up to operating temperature, there isn't really a problem. That's the way it's designed to work.
Does your engine idle at 700-750 RPM once warm?
Old Oct 17, 2010 | 04:14 PM
yea its a cold start i guess....when i first start it the idle is at 2500rpms...ive never had a car idle that high....is it adjustable?
Old Oct 17, 2010 | 04:17 PM
blown_ss's Avatar
yeah this is wrong. if your battery was drained then your car wouldnt start. it jumps to high idle so that the engine car warm to the right temp. once the car is warmed up the idle will come down to normal.
Old Oct 17, 2010 | 05:30 PM
95DX95's Avatar
Its the fast idle thermo valve (FITV). Just took it out on my car and cleaned it. Dont know what car you have but on my 95 civic dx its right under the throttle body. Its totally adjustable, look it up, dont feel like explaining lol.
15 minute job, nothings wrong though.
This thing:
Old Oct 17, 2010 | 07:05 PM
yea i have 1....92 dx with a gsr...i cleaned it like 2 months ago...maybe i didnt turn the screw thing inside down far enough.....
Old Oct 17, 2010 | 07:14 PM
Originally Posted by bLu92bUbbLe
92 dx with a gsr
As was stated in post #2, you must include this basic type of information about your car and engine in the First Post or Title of a tech thread. A failure to do so will lead to closure or deletion of your threads.
Again, please familiarize yourself with the stickies at the top.
Old Oct 21, 2010 | 12:54 PM
95DX95's Avatar
Just loosen the screw thing for it to idle lower, i think..
Old Oct 21, 2010 | 03:34 PM
TwoFacedCustoms's Avatar
Although this sounds normal....if you have a FITV...it's definitely not a bad idea to clean it...
Look at "Helpful Links" in RonJ@HT's signature box....^ there's a good write-up on how to clean it....
fessup
Honda CR-V & Element
Dec 7, 2017 01:11 PM
jdm_prelude19
Apr 4, 2011 05:58 PM
Upper Hand
Jun 12, 2008 05:02 PM
spock_rocker
Oct 17, 2007 08:11 AM
ThaCivicAssassin
Nov 30, 2006 01:55 PM
