dist never points at number 1, WHY?
Old Oct 14, 2010 | 08:30 PM
mccordelectric's Avatar
Default dist never points at number 1, WHY?
why is it when the engine on a honda is at TDC, and you install the distributor, it never points directly at number 1? in other words, it is not possible to static time a honda engine.
for instance, if you drop the dist into a small block chevy, when in correctly you can turn the dist so that the rotor is pointing directly at the number one plug wire, so the timing would be at 0 degrees if you had a timing lite on it.
on a honda, it is as close to number 3 as it is to number 1, and since you can only put the dist in 2 positions, not possible to get it any closer. I have noticed this on many hondas I have worked on.
Old Oct 14, 2010 | 08:34 PM
Former User's Avatar
Default Re: dist never points at number 1, WHY?
Are you sure the mechanical timing is correct?
What engine?
Old Oct 14, 2010 | 09:13 PM
1993 civic 1.6 vtec. absolutely sure cam timing is correct.
you are just used to it, but look at your car's rotor with the cap off and see if you can turn dist so it points directly at number 1. I bet you cant do it.
4drint3gr4
17
Oct 14, 2010 09:54 PM
stellium
Feb 25, 2010 03:27 AM
92H23VTEC
Jun 15, 2007 07:31 AM
krazn
Feb 22, 2004 11:11 AM
chictunner97ex
Jun 22, 2003 06:19 PM
