Mini me swap - Now throwing knock sensor, O2 heater, and EVAP pressure sensor codes
Old Oct 12, 2010 | 11:49 AM
Dstaks716's Avatar
Default Mini me swap - Now throwing knock sensor, O2 heater, and EVAP pressure sensor codes
I performed the swap 2 weeks ago! Car runs great but now throws these codes! I need to pass inspection and this is just setting me back even more and more. Is there any way I can disable it?
Po325 knock sensor 1
Po141 o2 heater bk1 sen 2 ( can not find the 2nd o2 sensor hook up wire on the whole damn car no way to hook up my 2nd sensor )
Po 453/450 evap pressure sensor swith
Anyone help me out ??? Thanks Derek
Old Oct 12, 2010 | 09:37 PM
Dstaks716's Avatar
Default Re: Mini me swap issues
wow thanks HT members
Old Oct 12, 2010 | 09:44 PM
ricky00's Avatar
wat car n year??
Old Oct 12, 2010 | 09:50 PM
speedooo's Avatar
Gee OP...thanks for not posting ANY relevant information. Try listing the model, trim, year, block, head, engine harness and ecu, and then MAYBE somebody will help you.
Old Oct 13, 2010 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
I'm assuming from your profile you have a 96 so you went OBD2. You'll need to get a knock sensor from a 96-00 Civic EX/any OBD0-1-2 DOHC VTEC Bseries engine and tap the block for the threads to use it. The secondary O2 sensor goes into the catalytic converter after the "header" portion of the D16Y8 engine and is integrated into the cars chassis harness, the y7 is integrated into the engine harness. You'll basically need to extend the secondary O2 sensor from your Y7 engine and use a cat that has an O2 bung in it or use your y7 exhaust manifold instead of the Y8's or whatever header you used. For reference. For the EVAP not sure just make sure you hooked it up, its on the fuel rail.
http://www.jdmuniverse.com/forums/view_minime.html
Old Oct 16, 2010 | 09:07 PM
Dstaks716's Avatar
96 ex mini me swaped. y8 block. obd 2. i thought the y7 and y8 had o2 sesnors?
excoupe00
Jun 6, 2009 09:18 AM
Crank
Sep 14, 2004 10:21 PM
EG6[B16A1]
Oct 19, 2003 11:22 AM
1.8EG-T
Nov 5, 2001 12:08 PM
