Ej8: 1997 coupe lower drivers side mount removal help!!!
Hey guys i need help removing my mount because it doesn't want to come off it seems like there is a nut inside holding it in but i know there shouldn't i need help thanks in advance.
if the nuts break off inside the frame they will spin. you can cut a small hole in the frame rail and tack the nuts back to the frame and then weld up the hole (hope you have a welder)
I had that happen to me.
Cut off the offending bolt with a Sawzall.
Use a 1" hole saw (or whatever size is close) and drill a hole in the frame rail where nut is supposed to be.
Remove the busted off nut and bolt-end.
Replace with a nut and bolt.
Don't worry about plugging the hole, but you could put a plastic plug in it.
turbohatch96y7
Welding / Fabrication
Apr 19, 2015 06:08 PM
LeonardDB
May 10, 2011 05:34 AM
MI4$DC5
Mar 26, 2006 04:43 PM
pearl
18
Jul 29, 2005 07:45 AM
