Ej8: 1997 coupe lower drivers side mount removal help!!!
Hey guys i need help removing my mount because it doesn't want to come off it seems like there is a nut inside holding it in but i know there shouldn't i need help thanks in advance.
Re: Ej8: 1997 coupe lower drivers side mount removal help!!!
are you talking about the torque mount? if so there should be one large bolt and two holding it onto the frame. can you take a picture of it ?
Yeah thats it i can't take a pic now because its too dark but the other two bolts don't want to screw off
if the nuts break off inside the frame they will spin. you can cut a small hole in the frame rail and tack the nuts back to the frame and then weld up the hole (hope you have a welder)
Do you know any threads that show you how to do it because thats exactly the problem
I had that happen to me.
Cut off the offending bolt with a Sawzall.
Use a 1" hole saw (or whatever size is close) and drill a hole in the frame rail where nut is supposed to be.
Remove the busted off nut and bolt-end.
Replace with a nut and bolt.
Don't worry about plugging the hole, but you could put a plastic plug in it.
turbohatch96y7
Welding / Fabrication
04-19-2015 06:08 PM
LeonardDB
05-10-2011 05:34 AM
pearl
18
07-29-2005 07:45 AM
