Ek b-serious swap - now speedometer doesn't work
Old Oct 7, 2010 | 10:35 PM
Batusi's Avatar
Default Ek b-serious swap - now speedometer doesn't work
I just did a swap into my 96 ek.. B16 and converted from auto to manual. My problem is that my mph doesn't work and I know for a fact it was working in my other civic with the same motor. Anyone know the problem??? lmk asap thanks
Old Oct 7, 2010 | 11:46 PM
Jdmglenn's Avatar
Default Re: Ek b-serious swap
did you plug in the wider 3 wire plug into the VSS on the tranny?
Old Oct 8, 2010 | 04:03 AM
dices543's Avatar
Check fuse 15 under the dash. Check if its blown.
Old Oct 8, 2010 | 06:38 AM
Former User's Avatar
Default Re: Ek b-serious swap - now speedometer doesn't work
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old Oct 8, 2010 | 07:40 AM
Jimster480's Avatar
Make sure to check the VSS. Because if you took it out of an EG then it is probably a 2 wire VSS, and 96-00 models need a 3 Wire VSS. If you have a 3 wire VSS in the tranny atm, then its either a fuse or the wiring is fkd up somewhere.
Old Oct 8, 2010 | 09:55 AM
94EG8's Avatar
Seagull Management
'92 - '95 VSS are also a 3 wire, they work the same. '92 - '95 have a plastic top half and a metal bottom half, '96 - '00 are 1 piece plastic.
OP what did you use for an engine harness.
Old Oct 8, 2010 | 01:57 PM
HondaPartsHero's Avatar
Technical Hero
http://techauto.awardspace.com/vss.html
suproman
Oct 25, 2010 12:11 AM
atownludeh22a
Jan 11, 2009 01:32 PM
JdMmeeH
Dec 18, 2008 05:39 PM
antigram
Dec 6, 2008 03:10 PM
opiumdaze
Sep 17, 2006 09:15 PM
