Ek b-serious swap - now speedometer doesn't work
I just did a swap into my 96 ek.. B16 and converted from auto to manual. My problem is that my mph doesn't work and I know for a fact it was working in my other civic with the same motor. Anyone know the problem??? lmk asap thanks
Re: Ek b-serious swap - now speedometer doesn't work
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Make sure to check the VSS. Because if you took it out of an EG then it is probably a 2 wire VSS, and 96-00 models need a 3 Wire VSS. If you have a 3 wire VSS in the tranny atm, then its either a fuse or the wiring is fkd up somewhere.
Seagull Management
'92 - '95 VSS are also a 3 wire, they work the same. '92 - '95 have a plastic top half and a metal bottom half, '96 - '00 are 1 piece plastic.
OP what did you use for an engine harness.
JdMmeeH
12-18-2008 05:39 PM
