B20 Vtec Question please help.
Old Sep 27, 2010 | 03:38 PM
digitaldetox's Avatar
Default B20 Vtec Question please help.
running a b20b block with knock sensor. and a b16 head. i did a dry compression test and it was 142 in all cyclinders. is that normal? or could it need a valve adjustment?
Old Sep 28, 2010 | 09:11 PM
barrywayne's Avatar
Default Re: B20 Vtec Question please help.
as far as i know, if all of the cylinders read the same then its normal but i could be wrong.
Old Sep 28, 2010 | 09:54 PM
XRS Joe's Avatar
thats normal for b20 becuase of their low comp pistons. now if it was a b20z, then youre numbers are a bit diff. does the car start up and rev fine?
Old Sep 28, 2010 | 09:57 PM
barrywayne's Avatar
And if its a b20z with a b16 head with those numbers then its very low
Old Sep 28, 2010 | 10:12 PM
XRS Joe's Avatar
the last time i did a compression check on a stock b20, compression was 160 on all cylinders. you might wanna check valve adjustment and maybe the head is not properly fastened. check the torque specs if it is still tight. could also be piston rings. but if your car runs fine and does not idle funny or feel weak then your fine. i cant really give you a complete diagnosis because i only have a few info from you.
Old Sep 29, 2010 | 06:37 PM
rego1988's Avatar
valve adjustment. if the car is smoking then my guess would be piston rings because the compression in my old LS was 180psi
Timothy Yhtomit
Feb 7, 2018 06:42 PM
killer833
Dec 6, 2013 06:21 PM
Jurassic Four
Jun 25, 2004 06:58 AM
. o 69 o .
Jan 24, 2002 07:37 PM
jdmR
Dec 20, 2001 03:38 PM
