EG - OIL PRESSURE LIGHT and low oil pressure with engine running
Old Sep 24, 2010 | 02:41 PM
arkomandos's Avatar
Default EG - OIL PRESSURE LIGHT and low oil pressure with engine running
HELLO everybody,,,,,,,I was driving around with my car couple days ago,,,after 20 min of driving noticed the oil light flicking at first then it just went on,,,,I actually think the pressure might be too lean is that possible,,,,when starting the car at cold its right under 80 that seems right,,,,at idle it was 15-25 when hot,,,,but when the light went on it was 5 and hitting 0,,,,,,I don't think the gauge is broken,,,,timing is right on,,,,the distributor o ring leaks a tiny bit of oil but,,,only a drop or 2,,,,,,ANY IDEAS,,,,
Old Sep 24, 2010 | 05:02 PM
canadaek's Avatar
Default Re: EG,,OIL PRESSURE LIGHT
poss bad sender or oil pump do you have a gauge and light ? if so how are they mounted ? i had a remote mount on my old ef and it would collect moisture in the line and mess up the sender take off the line clean it out it would be good again.
Old Sep 24, 2010 | 05:44 PM
Former User's Avatar
Did you check the oil level? If that's fine, the oil pump may be failing.
Old Sep 26, 2010 | 10:03 AM
arkomandos's Avatar
Default Re: EG - OIL PRESSURE LIGHT
no way man oil pump 4 months old,,,oil level good,,,
Old Sep 26, 2010 | 10:13 AM
arkomandos's Avatar
oil pump and water pump new,,,yes I have a 3 pillar gauge,,
I used this link as my guide
http://doitrightinjection.com/gaugemountinst.html
I did notice another leak behind the vtech solenoid,,,I will take off my intake manifold cause I cant really see,,but its not a head gasket for sure,,,
Old Sep 26, 2010 | 12:35 PM
hatchaddict01's Avatar
Default Re: EG - OIL PRESSURE LIGHT and low oil pressure with engine running
were did you buy the oil pump? is it a cheapo rebuild or is it new oem from dealer
Old Oct 3, 2010 | 10:23 AM
arkomandos's Avatar
its a new oem pump ,,,car runs on a base ectune,,its also running rich on fuel but,,,that's normal,,,,,,,and I was thinking maybe its the tune that I need,,,,,
Old Oct 3, 2010 | 11:17 AM
D16SiHatch's Avatar
tune isn't going to fix oil pressure man. it should never drop that low.
Old Oct 3, 2010 | 11:59 AM
92cxhatch169's Avatar
maybe a bad oil pressure sensor? is your car turbo? where are you getting your oil feed from?
Old Oct 6, 2010 | 01:38 PM
arkomandos's Avatar
well from the back of the block,,,,running a obx braided steel feed ,,,and a obx oil restrictor,,,,yea but would it be the one next to the coolant temp sensor,,,or the one in the back?????
Old Oct 6, 2010 | 02:05 PM
there is only one oil pressure sensor unless you consider the one on the vtec solenoid but if your mechanical gauge says 0 and your light is on then you have a problem with oil pressure not a sensor
Old Oct 6, 2010 | 03:56 PM
brian15's Avatar
When mine had this same issue , it ended being spun bearings. The op light would flicker while comming to a stop then go away while moving.
If none of the simple ideas turn out to be true then drain the oil and pull the pan....check for bearing shavings
Old Oct 19, 2010 | 01:58 PM
arkomandos's Avatar
it was a bad sender,,,thanks for all your posts,,,,
xlasianizelx
Aug 10, 2010 02:28 PM
rich7777
Nov 11, 2009 05:29 PM
junior_tm
Jul 1, 2009 11:22 AM
antiJDM
Jan 30, 2008 02:32 PM
GruvyTune
Jul 9, 2004 07:16 AM
