95 Civic: Starter won't crank engine
Old Sep 15, 2010 | 02:31 PM
vladiscoolej1's Avatar
Default 95 Civic: Starter won't crank engine
Hey i have a 95 civic ex 5sp. It has a d16z6. I was driving the car daily and then one day it just doesn't start. The starter doesn't crank or anything. All i hear when i try to start it is clicking next to the fuses by the steering wheal. I already tried jump starting it and push starting it and no success with either. The lights and radio and all that stuff work too. I checked all the fuses and cleaned the battery terminals. What is going on??
Old Sep 15, 2010 | 02:34 PM
delsolproblems's Avatar
Default Re: 95 Civic wont start
Use a meter on the starter wires to see if it is getting power while someone turns the key. If not, switch the black probe to the battery negative post and see if you then read voltage (if you do then it's a bad ground). If it does get power, remove and replace.
Old Sep 15, 2010 | 03:53 PM
honda fossil's Avatar
remove the black wire on the starter silnoid (it a female terminal with a black hat) hook up your test light to that wire and the neg battery and should light up every time the key is moved to start. make sure the engine turns over freely cuz if it didnt start when trying to push start then the engine may be lock up or you didn't do i right
Old Sep 15, 2010 | 04:13 PM
Former User's Avatar
Default Re: 95 Civic: Starter won't crank engine
Check the battery and the ignition switch:
Old Feb 16, 2011 | 05:30 PM
slowwcivic's Avatar
i have same problem turn the key nothing happens i get a click from under the hood fuse box n i put a lead on the female plug that connects to the starter and on the negative on the battery n i got nothing
Old Feb 16, 2011 | 05:58 PM
Originally Posted by slowwcivic
...n i put a lead on the female plug that connects to the starter and on the negative on the battery n i got nothing
Both wires attached to the starter are power wires. There is no ground wire.
Old Oct 2, 2014 | 09:36 AM
EthanW's Avatar
I had this problem today. I shorted out the clutch starter safety switch and it fired up. Replacement part is $40 at Advance.
killaberna
Sep 9, 2015 07:56 PM
JJT211
Jun 22, 2014 08:33 PM
Eklove2496
May 17, 2014 09:03 PM
eg_beast
May 4, 2009 04:57 AM
OPTION2ek V.2
Jul 18, 2005 10:05 PM
