Start up problems
Old May 17, 2014 | 07:55 PM
Eklove2496's Avatar
Default Start up problems
Got this 95 teggy, tried to start it up and I get no cranks. Had the car sit for a week and a half so I charged the battery completely and still no crank what could this be? The guy installed an electrical push to start button on the car worked fine before now it just stopped working.
Old May 17, 2014 | 08:05 PM
SpokaneSpeed's Avatar
Default Re: Start up problems
Start with confirming battery voltage, from there confirm you are getting 12v at the solenoid wire @ starter when push button starter is depressed. If not, work backwards towards the starter switch. But knowing it has a modified push button starter - I would start there and verify its giving a 12v signal out...
Old May 17, 2014 | 08:36 PM
ef2_civic's Avatar
Agreed
Old May 17, 2014 | 09:03 PM
fcm's Avatar
fcm
Old Fart
You did not search at all, did you...
https://honda-tech.com/forums/tech-misc-15/simple-diy-start-circuit-test-%5Bbypass-jump%5D-2961164/
One more thing, you did what a lot do not, you at leased providid year and model of the car you needed technical info on, MM&Y along with trim level and auto or 5 speed make helping a lot easier and cuts down on postings. 94
gooblinn258
Dec 16, 2013 08:23 AM
eg_beast
May 4, 2009 04:57 AM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
DAYUIZ
Jan 20, 2004 03:03 PM
