I have a few questions about adding keyless and auto start into 98 civic.
Old Aug 30, 2010 | 09:22 PM
98civdx's Avatar
Master Detailer
Default I have a few questions about adding keyless and auto start into 98 civic.
Car is a 98 civic dx auto
Alarm is a clifford Matrix 3.3x, 2 way
This is what i have so far and im wondering if it is correct.
This is off the 10pin(h3)
Red, Red/black and Red/white go to the white 12volt+ in car, on igntion harness
All three on the same wire??
The Orange will go to the yellow ignition wire in car.
Off 5 pin
Blue/white-dont need (rs in)
Gray-hood pin
brown- brake goes to Green/white in car
Violet/white- Tach wire
Black/white- Ground
As for the keyless can i just splice the green and blue coming from the brain to 2 actuators?
Thanks, i did post this in the security section, however it takes a long time to get a answer.
Old Aug 31, 2010 | 06:03 AM
98civdx's Avatar
Master Detailer
Default Re: I have a few questions about adding keyless and auto start into 98 civic.
Anyone??
Old Aug 31, 2010 | 07:13 AM
tlarimer's Avatar
Try moving over to audio/video/security section, those guys in that section are very knowledgable and should be able to help you out.
Old Aug 31, 2010 | 10:19 AM
98civdx's Avatar
Master Detailer
thanks, I know that. I already did it just it takes a long time to get anything.
Last question took 2 weeks and 300 views before anyone posted.
Old Aug 31, 2010 | 10:41 AM
tlarimer's Avatar
I figured you did.
I am in the same boat, adding remote start/keyless entry to my wifes 99 Civic LX auto, but using a different system.
Good luck with finding your answers.
Old Aug 31, 2010 | 10:51 AM
D16SiHatch's Avatar
can't find an installation guide for the particular alarm you are using so i'm not sure on where your wires should go.
i can tell you that the green and blue wires for the door locks from the brain cannot go straight to the actuators. these wires use a negative pulse to trigger either a factory or aftermarket power door lock relay.
Old Aug 31, 2010 | 12:14 PM
98civdx's Avatar
Master Detailer
Thanks guys, I can't find an install guide either. All I have so far is what they are for.
I figuring id need a relay for them, but hoping I didnt
Old Aug 31, 2010 | 11:45 PM
98civdx's Avatar
Master Detailer
Come on guys? I know someone knows something.
At this point anything would help!!
Old Sep 1, 2010 | 09:44 AM
D16SiHatch's Avatar
all i can find are viper product install guides, and they don't appear to have the same wiring as what you've got. i've searched high and low and can't find a single install guide for a clifford matrix alarm system. i read somewhere that the dealers only give out guides and not the install manuals because they only want certified shops to install the alarms, not people to do it themselves. dunno how true that is or not, all i know is i can't find bupkis
Old Sep 1, 2010 | 10:13 AM
98civdx's Avatar
Master Detailer
Thanks for looking sir.
I have looked and find anything, and no one seems to know for sure.
Someone pointed out to me I can use a dei 451M for my door locks instead of 2 relays.
Old Sep 1, 2010 | 12:21 PM
D16SiHatch's Avatar
yes you can go either route
micro relay
or 2 SPDT 5-wire relays
and even 4 4-wire SPST relays, if you just happen to have a lot of them laying around lol
Old Sep 1, 2010 | 01:39 PM
98civdx's Avatar
Master Detailer
Ok, thanks for posting that, honestly I think im just going to get the dei 451M and go that route.
Talked to both car toys and clifford and they were no help, besides car toys wanting 300 for remote start
Old Sep 2, 2010 | 12:52 AM
98civdx's Avatar
Master Detailer
Alright i think i finaly got it.
10 Pin heavy guage
Alarm side ------- Car side
Red 12volt+ -------- White- 12V constant
Red/white ------- Black/yellow (ignition) I think this is it
Red/black ------- Starter- Black/white
Orange Accssory out ----- White/black
5 Pin
Gray-Hood pin
Brown- Brake pedel ----- Green/white Shows 12v while on brakes
Violet/white- Tach ------ Blue
if any one could confirm this??
Old Sep 7, 2010 | 12:46 PM
98civdx's Avatar
Master Detailer
ok, so i just got the dei 451M, and the instructions it comes with it is kind of confusing.
just to make sure i have this right.
Violet and violet/black go to 12 volt source. 15 amp fuse, both turn into one wire
ground is white/black and brown/black
Blue/Black and Green/black to actuators
And then the 3 pin with Red,green/blue plugs into the spot on the brain for the keyles
Is this right??
And about the remote start, they all just crimp onto the white or is the a certain way to connect them?
Thanks for the help, im headed out to my car right now to start installing everything.
Old Sep 7, 2010 | 07:47 PM
D16SiHatch's Avatar
sounds like you've got it right for the 451m.
not sure what you're asking in regards to the remote start
Old Sep 8, 2010 | 10:50 AM
98civdx's Avatar
Master Detailer
Actuators are in and working correctly, but they don't fit. I'll need smaller ones.
In regards to the autostart, someone told me all the red wires go to the white wire in the ingnition harness.
Just trying to confrim.
Old Apr 10, 2013 | 10:22 AM
verchiang's Avatar
does anyone know how an auto start works on a manual car?
Old Apr 10, 2013 | 12:19 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Yes; Google does. You have not done enough research to warrant asking this very vague question. Thread closed.
ryaned380
Audio / Security / Video
Dec 12, 2019 06:06 AM
larueminati
Sep 3, 2012 04:43 PM
Mikal92
33
Mar 30, 2009 08:02 PM
winneth
Jun 19, 2007 06:30 PM
DC2 to AP2
Jan 11, 2005 12:13 PM
