hi, im attempting to install a viper 5704 alarm system on auto 96 integra and i need help to figure out what wires/connections do not need to be used and where some wires go. feel free to make corrections if i am wrong, and please help answer some of my questions (in bold)
thank you in advance
(took this list from Orange_SIR1)
Main Harness 6 pin
h1/1 red const 12v - tap to a const 12v source
h1/2 black grnd - chassis ground
h1/3 brown siren out - connect to direct to siren
h1/4 white/brown park light isolation wire - is this needed?
h1/5 white park light out - tap to park lights
h1/6 orange ground when armed output - where to ground this?
Door lock 3 pin
1 blue out - tap to neg unlock
2 n/a
3 green - tap to neg lock
Aux/shutdown/trigger harness, 24 pin
h2/1 pink/white ign/flex relay out - where to tap this?
h2/2 black/white neutral safety input - tap to e brake?
h2/3 blue white 2nd stat/rear defog out - tap to defogger
h2/4 green black oem alarm disarm out - n/a
h2/5 red/white trunk release out - tap to trunk release
h2/6 green door trigger input (-) - tap this to where?
h2/7 black/yellow dome light supv out - connect to relay/lights
h2/8 brown/black horn honk - tap to horn
h2/9 dark blue status out - where to connect this?
h2/10 pink ign out - where to connect this?
h2/11 white/black aux3 out - n/a
h2/12 violet (+) door trigger in - where to connect this?
h2/13 white/violet aux1 out - n/a
h2/14 violet/black aux2 out - n/a
h2/15 orange/black aux4 out - n/a
h2/16 brown brake shutdown in - tap to brake wire switch above pedal
h2/17 grey hood pin - to hood pin
h2/18 violet yellow starter out - is this needed?
h2/19 blue instant trigger in - connect to the other sensors
h2/20 grey/black diesel wait to start - is this needed?
h2/21 white/blue remote start/tt acvt in - is this needed?
h2/22 orange acc out - is this needed?
h2/23 violet/white tach in - tap to car's tach
h2/24 oem alarm out - n/a
remote start 10 pin heavy gauge really confused with harness
h3/1 pink ign in/out (+) - tap to ign or const 12v?
h3/2 red/white fused ign2/flex relay in - is this needed?
h3/3 orange acc out - tap car's acc
h3/4 violet start out - cut starter wire then connect this to starter side
h3/5 green starter in - key side of cut starter wire
h3/6 red ign in (+) - tap to ign?
h3/7 pink/white ign2 out - where to tap this?
h3/8 pink/black flex relay in - is this needed?
h3/9 red/black acc/starter in - tap to const 12v
Main Harness 6 pin
Door lock 3 pin
2 n/a
Main Harness 6 pin
h1/4 white/brown park light isolation wire - is this needed?-Not needed
h1/6 orange ground when armed output - where to ground this? Not needed unles you plan on adding extra kills or accesories
Door lock 3 pin
2 n/a
h2/1 pink/white ign/flex relay out - where to tap this? Not needed
h2/2 black/white neutral safety input - tap to e brake? E brake for saftey. At ebrake or behind cluster
h2/6 green door trigger input (-) - tap this to where? Driver door pin, driver a pilliar
h2/9 dark blue status out - where to connect this? Not needed unless using a back up battery moduel
h2/10 pink ign out - where to connect this?not needed
h2/12 violet (+) door trigger in - where to connect this?not needed
h2/18 violet yellow starter out - is this needed?not needed
h2/20 grey/black diesel wait to start - is this needed? Not needed
h2/21 white/blue remote start/tt acvt in - is this needed? only if you want push button start or turbo timmer
h2/22 orange acc out - is this needed? Not needed
h3/2 red/white fused ign2/flex relay in - is this needed? 12 volts
h3/6 red ign in (+) - tap to ign? 12 volts
h3/8 pink/black flex relay in - is this needed? Not needed
h3/9 red/black acc/starter in - tap to const 12v12 volts
I think you might be over your head on this.Originally Posted by larueminati
hi, im attempting to install a viper 5704 alarm system on auto 96 integra and i need help to figure out what wires/connections do not need to be used and where some wires go. feel free to make corrections if i am wrong, and please help answer some of my questions (in bold)thank you in advance
Main Harness 6 pin
Door lock 3 pin
2 n/a
Main Harness 6 pin
h1/4 white/brown park light isolation wire - is this needed?no
h1/5 white park light out - tap to park lightsmake sure the small 10a fuse goes from the middle to the + on the module
h1/6 orange ground when armed output - where to ground this?this is only needed for fuel cut offs/etc don't need
Door lock 3 pin
2 n/a
h2/1 pink/white ign/flex relay out - where to tap this?not needed if setting up remote start. gets the ign input from the thick gauge
h2/2 black/white neutral safety input - tap to e brake?yes
h2/8 brown/black horn honk - tap to hornmight need relay. most don't use
h2/9 dark blue status out - where to connect this?don't need
h2/10 pink ign out - where to connect this?same as pink. only needed if remote start thick gauge aren't used.
h2/12 violet (+) door trigger in - where to connect this?not needed since honda door trigger inputs are (-) which is why you use the green wire
h2/18 violet yellow starter out - is this needed?same as the ignition. only needed if remote start isn't hooked up
h2/20 grey/black diesel wait to start - is this needed?no
h2/21 white/blue remote start/tt acvt in - is this needed?no
h2/22 orange acc out - is this needed?no
h3/1 pink ign in/out (+) - tap to ign or const 12v?ignition
h3/2 red/white fused ign2/flex relay in - is this needed?no
red wires with fuses need to go to a 12v source. iginition 2 is not used in your vehicle so you can de-pin the 12v ignition 2 input and ignition 2 wire.Originally Posted by larueminati
Main Harness 6 pin
Door lock 3 pin
2 n/a
please click this link and read it thoroughly. most of my information should be correct but i might have accidentally mistaken some things.
http://www.civic-eg.com/causeforalar...egra/index.php
Bradshaw you are wrong on the remote start. Please dont come in posting wrong information when the correct information has allready been posted. The red/black wire needs to see 12 volts during remote start. And depinnig the pink and white leaves one extra wire on the ignition harness not tagged. So either the heater is not going to blow or the car radiator fan is not going to come on depending on year.
