Remote Start Problem
Old Mar 20, 2009 | 09:24 PM
Mikal92's Avatar
Default Remote Start Problem
My remote start won't start here is what my manual says how to wire it. Red = Main power. I have this connected to White the 12v constant under the dash.
Pink = Ignition output. I have this connected to the black wire with yellow stripe. Pink = Ignition 2. I have this connected to nothing. Orange = Accessory output. I have this connected to the Yellow wire near the steering wheel column. Purple = Starter. I have this connected to the black wire with a white stripe. Blue/White = bypass output. I don't have this connected to anything. Grey/Black = Diesel wait to start bulb. I don't have this connected.
Black//White= Neural Safety Switch Input. I have this connected to the Green with a white stripe wire by the gear shifter. Purple/White = Tach Wire Input. to the blue wire near the firewall on the driver side. Can you help thanks
Old Mar 21, 2009 | 12:34 AM
orangebang49's Avatar
New User
Default Re: Remote Start Problem
What kind of alarm? What's the year and make of your honda????????
Old Mar 21, 2009 | 08:05 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^.
MM&Y of car?
Make and model of remote start?
Is car an automatic or a standard? 94
Old Mar 21, 2009 | 09:11 AM
Mikal92's Avatar
95 Acura Integra automatic
It is an alarm off ebay so I don't know the name of it. It says 2300 series and thats it.
Old Mar 21, 2009 | 02:16 PM
Mikal92's Avatar
Now that I hooked up the starter kill the doors will only unlock and the ac is always on.
Old Mar 21, 2009 | 03:11 PM
fcm's Avatar
fcm
Old Fart
Something is mysteried, can you post a pix of wiring diagram it came with, or a link to the eBay vendor. 94
Old Mar 21, 2009 | 03:14 PM
Mikal92's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...t_14571wt_1193
Here Is a link to the item Ill take some pics right now.
Old Mar 21, 2009 | 03:18 PM
Mikal92's Avatar
Can't get a clear pic but heres what it says. For the relay
Yellow to Ground when alarmed output.
Green to alarm constant power.
Green to Ignition of key cylinder input.
Orange to Ignition of key cylinder input
Old Mar 21, 2009 | 03:59 PM
fcm's Avatar
fcm
Old Fart
What???
Need pix.94
Old Mar 21, 2009 | 04:10 PM
Mikal92's Avatar
diagram of the alarm manual or for the teg?
Old Mar 21, 2009 | 06:00 PM
KCUF_DB8's Avatar
How is the alarm?
fcm i'm wondering with these type of no brand alarms. does th DEI520T back up battery work with them?
Old Mar 21, 2009 | 08:29 PM
Davus's Avatar
Originally Posted by KCUF_DB8
How is the alarm?
Yes it does. The alarm should have some sort of instant/trunk/hood trigger you can tie into, or just the door trigger if that fails.
Old Mar 21, 2009 | 10:08 PM
Mikal92's Avatar
Thats what I did. I think all the add-on's are compatible.
Old Mar 22, 2009 | 07:12 AM
fcm's Avatar
fcm
Old Fart
Alarm.94
Old Mar 22, 2009 | 12:02 PM
Mikal92's Avatar
http://www.scribd.com/doc/377594/Install-Guide
Old Mar 22, 2009 | 10:08 PM
lazii_boi08's Avatar
that alarm is a fake python version but anyways have u tried grounding the neutral safety switch that what i ussualy do and did u program the tach wire???
Old Mar 22, 2009 | 10:58 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
A member allready brought one to me saying it was a dei alarm. The person who sold it to him told him it was one. I will look to see if I can find the directions to it. It never worked right out the box.
Old Mar 23, 2009 | 02:49 PM
Mikal92's Avatar
I tried that how do you program the tach. My manual says just connect it to the tach or go tachless.
Old Mar 24, 2009 | 05:52 PM
Mikal92's Avatar
Ok I rewired the starter kill and now its cranking but not starting it starts to crank as soon as I connected the battery.
Old Mar 24, 2009 | 08:36 PM
sik96teg's Avatar
on some alarms there is a wire used for in car button start (like the s2000)make sure u dont have that wire hooked up, that ebay alarm is almost the same as the one i use to have and now i have a viper but the wire colors are almost all the same. if you are still having issues post back and i can look at my wiring and tell you where everything goes
Old Mar 25, 2009 | 03:43 PM
Mikal92's Avatar
I don't have a wire for the car button start. Can you tell me how you wired your starter kill and if you cut any wires. Thanks
Old Mar 25, 2009 | 04:58 PM
fcm's Avatar
fcm
Old Fart
Yes you must cut the starter wire, [black/white] connect one of the cut ends, [ign. switch end] to #30 of the relay the other cut end, [starter motor end] goes to #87a, you can connect a "true" ign., [hot in run and start] or starter wire, [ign. switch end] to #85 and the alarms orange wire, [from 6P harness] to #86... http://www.the12volt.com/relays/page2.asp
You may want to read up on how relays work... http://www.the12volt.com/relays/relays.asp
When connecting the remote starts starter output, [purple] make sure it is on starter motor side of the starter cut relay.
For tach, [purple/white] connect that to one of the injectors, [lead that is a diff. color on each injector.
Make sure the parking brake, [black/white] is grounded, this lead can be permanently grounded as your car will not crank if not in park or neutral, you can also connect the lead to an on/off toggle switch to supply it with a ground, [when switch is on] and use the switch as a "service" switch.94
Old Mar 25, 2009 | 08:07 PM
Mikal92's Avatar
I wired everything up like you said and it still won't remote start.
Old Mar 26, 2009 | 05:02 AM
fcm's Avatar
fcm
Old Fart
Return unit, it is defective. 94
Old Mar 26, 2009 | 05:10 AM
SGT.AROD's Avatar
New User
Make sure that you have the wire that goes to the starter is plugged in the right way> also the alarm should have a hood pin check that if the car is stick you need a bypass > make sure the brake wire is hooked up> other than that check ur wiring again......
