Help! Neutral Safety Switch? No Crank
Old Aug 30, 2010 | 06:40 PM
lilmarcEH3's Avatar
Default Help! Neutral Safety Switch? No Crank
1992 Honda Civic Si
Ok, so the other day, I go to start my car, and there is no cranking at all. No nothing.
I look down at the floorboard and the little pedal stopper was laying there. Ok, no big deal, I get a new one from Honda and put it in.
But now I still can't get it to crank or anything! I am really doubting the likelihood of the Neutral Safety Switch failing at the same time as the pedal stopper, but who knows.
Is there anything I should have to do after putting a new pedal stopper in?
I need my car to be able to start! I can only start it by popping the clutch, and that is very inconvenient.
Thanks Honda-Tech
Old Aug 30, 2010 | 06:56 PM
lilmarcEH3's Avatar
Default Re: Help! Neutral Safety Switch? No Crank
Bumpppp I need this car up and running
Old Aug 30, 2010 | 07:16 PM
habib's Avatar
If you can roll start it, then i would say it would be the neutral safety switch, you can bypass it to test to see wether or not it is that
Old Aug 30, 2010 | 07:18 PM
lilmarcEH3's Avatar
What is the best way to bypass it? Jump the connector with a paper clip or something of the like?
Old Aug 30, 2010 | 07:20 PM
habib's Avatar
yea, just get the wires to touch each other so power can go through
Old Aug 30, 2010 | 07:24 PM
DCSportEJ1Civic's Avatar
does the switch height need adjusted? maybe when your pressing the clutch in its not pressing the switch in.
Old Aug 30, 2010 | 07:25 PM
lilmarcEH3's Avatar
No it's being pressed in just fine.
What if when I bypass it, the car still won't start?
Old Aug 30, 2010 | 07:30 PM
you can bypass it by jumpering the harness as someone else said. if it starts you have a bad switch, if not it's something else. you can also test the switch with a DVOM and see if its working or not.
Old Aug 30, 2010 | 07:47 PM
D16SiHatch's Avatar
if it's not the nss then i would look at the ignition switch next
Old Sep 1, 2010 | 05:59 AM
JDM-KIDD's Avatar
on the clutch petal there should be a sensor or somethin u should be able to take that out and u should b able to start it with out even pushin clutch in.... i know for a Fact there on Egs dunno bout EK.... and i dun even know what kinda car u got lol in school now doin this but yeah hope it helps u....
Old Sep 1, 2010 | 10:01 AM
Former User's Avatar
If you have cruise control, the clutch pedal has two separate switches. The upper one is the safety starter switch and the lower one is the cruise control switch.
J3450
Mar 18, 2012 09:43 PM
AlfieRoach
Jun 17, 2010 05:47 PM
95slomocivi
May 14, 2010 03:14 PM
omgwtfbbq
Oct 20, 2009 06:48 PM
wambus
Jul 14, 2006 01:12 PM
