making traction bars fit 99-00 SIR
Searched a bit and couldnt find anything concrete on this, so here goes.
Installing traction bars on a 99-00 civic SIR (canadian) - what mods need to be done to the LCA's, or what other LCA's will fit that have the needed bolt to attach the traction bars bracketry to?
I would like to fit up a set of Avid bars, but they list that they will not fit this model's LCA's.
Anyone have a decent solution?
Generally traction bars will only fit ex/hx style control arms.
Doing so, would mean you would also need to replace your endlinks with, i think Integra type r endlinks. Or run a ex style front sway bar.
Most aftermarket companies say to weld the traction bars on the SIR/Si... You can swap out the LCAS with one from another 96-00 civic but you will also have to run a swaybar from that civic as well...
98CX
16
Nov 18, 2009 11:19 PM
